VG202XM configuration
yixiu0317
Hi     there,
I got a VG202XM fax gateway to be configured, for some reason the auto configuration does not work.
It failed to find the correct tftp server and keeps trying to connect to the 255.255.255.255.
I followed the instruction about how to configured VG202, and the same configuration worked on the VG202
Here is the configuration, I have configured ccm-manager sccp, but since it can not get the configuration and the command was removed.
ip cef
no ipv6 cef
stcapp ccm-group 1
stcapp feature access-code
stcapp feature speed-dial
voice service voip
voice-card 0
interface FastEthernet0/0
ip address dhcp
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
ip forward-protocol nd
no ip http server
control-plane
voice-port 0/0
timeouts initial 60
timeouts interdigit 60
timeouts ringing infinity
voice-port 0/1
ccm-manager sccp local FastEthernet0/0
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
dial-peer voice 999000 pots
service stcapp
port 0/0
ip cef
no ipv6 cef
stcapp ccm-group 1
voice service voip
voice-card 0
ip address dhcp
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
no ip http server
control-plane
voice-port 0/0
timeouts initial 60
voice-port 0/1
service stcapp
port 0/0
and here is the error message.
%Error opening tftp://255.255.255.255/network-confg (Timed out)
%Error opening tftp://255.255.255.255/bombovg202_2-confg (Timed out)
*Mar  3 17:52:05.571: %SYS-4-CONFIG_RESOLVE_FAILURE: System config parse from (tftp://255.255.255.255/network-confg) failed
*Mar  3 17:52:05.575: %SYS-4-CONFIG_RESOLVE_FAILURE: System config parse from (tftp://255.255.255.255/bombovg202_2-confg) failed
%Error opening tftp://255.255.255.255/cisconet.cfg (Timed out)
%Error opening tftp://255.255.255.255/bombovg2.cfg (Timed out)
*Mar  3 17:52:43.571: %SYS-4-CONFIG_RESOLVE_FAILURE: System config parse from (tftp://255.255.255.255/cisconet.cfg) failed
*Mar  3 17:52:43.575: %SYS-4-CONFIG_RESOLVE_FAILURE: System config parse from (tftp://255.255.255.255/bombovg2.cfg) failed.
*Mar  3 17:55:21.571: %SYS-4-CONFIG_RESOLVE_FAILURE: System config parse from (tftp://255.255.255.255/network-confg) failed
*Mar  3 17:55:21.575: %SYS-4-CONFIG_RESOLVE_FAILURE: System config parse from (tftp://255.255.255.255/bombovg202_2-confg) failed
% Bad IP address or host name
% Unknown command or computer name, or unable to find computer address
5 Replies 5
Chris Deren
Are you trying to use SCCP or MGCP as you have both configured?
Chris
Hi             Chris,
I am trying to use SCCP and CUCM version is 7.13.
even though I configured the tftp server (ccm-manager config server ip address), it won't use it to download the file, it keeps contacting 255.255.255.255.
SCCP does not use this command, all you need for SCCP is:
stcapp
stcapp ccm-group 1
sccp ccm identifier 1 version 7.0
sccp ccm identifier 2 version 7.0
sccp
sccp ccm group 1
bind interface FastEthernet0/0
associate ccm 1 priority 1
associate ccm 2 priority 2
voice-port 2/0
caller-id enable
dial-peer voice 100 pots
service stcapp
port 2/0
HTH,
Chris
Hi             Chris,
Before when I configure the VG202, I just need to configure below command and it will automatically download the file from CUCM, but now it did not work. I will try your commands tomorrow and let you know if it works.
Interface fa0/0
ip address dhcp
not shu
ccm-manager sccp
Not sure how that could have used for you without pointing to anything. Let us know if your issue is resolved by marking the thread as answered.
Chris
