VG204 not register
fuhdan
I have a VG204 with IOS: vg20xxm-ipvoice-mz.159-3.M.bin
But I can't register the VG204 to my CUCM 11.5
VG Config:
stcapp ccm-group 1
stcapp
stcapp feature access-code
stcapp feature speed-dial
voice service voip
no supplementary-service sip handle-replaces
fax protocol t38 nse force version 0 ls-redundancy 0 hs-redundancy 0 fallback cisco
voice-port 0/0
cptone CH
timeouts initial 60
timeouts interdigit 60
timeouts ringing infinity
voice-port 0/1
cptone CH
timeouts initial 60
voice-port 0/2
cptone CH
timeouts initial 60
voice-port 0/3
cptone CH
timeouts initial 60
sccp local FastEthernet0/0
sccp ccm cucmpub identifier 1 version 7.0
sccp ccm cucmsub identifier 2 version 7.0
sccp
sccp ccm group 1
associate ccm 1 priority 1
associate ccm 2 priority 2
ccm-manager config server cucmpub
ccm-manager sccp local FastEthernet0/0
ccm-manager sccp
dial-peer voice 999000 pots
service stcapp
port 0/0
dial-peer voice 999001 pots
service stcapp
port 0/1
dial-peer voice 999002 pots
service stcapp
port 0/2
dial-peer voice 999003 pots
service stcapp
port 0/3
So the voice ports are done by CUCM like the config on the voice-ports.
On the CUCM I added the SCCP Gateway, but the gateway is not registering.
I get the following logs on the VG:
sccp_xlate_voip_codec_type: payload 8 may be not supported or invalid payload type
*Mar 3 17:48:57.791: sccp_dev_set_codecs: unsupported codec type 8
*Mar 3 17:48:57.791: sccp_xlate_voip_codec_type: payload 9 may be not supported or invalid payload type
*Mar 3 17:48:57.795: sccp_dev_set_codecs: unsupported codec type 9
*Mar 3 17:48:57.795: sccp_xlate_voip_codec_type: payload 14 may be not supported or invalid payload type
*Mar 3 17:48:57.795: sccp_dev_set_codecs: unsupported codec type 14
*Mar 3 17:48:57.795: sccp_xlate_voip_codec_type: payload 15 may be not supported or invalid payload type
*Mar 3 17:48:57.795: sccp_dev_set_codecs: unsupported codec type 15
*Mar 3 17:48:57.795: sccp_xlate_voip_codec_type: payload 7 may be not supported or invalid payload type
*Mar 3 17:48:57.795: sccp_dev_set_codecs: unsupported codec type 7
*Mar 3 17:48:57.795: sccp_xlate_voip_codec_type: payload 2 may be not supported or invalid payload type
*Mar 3 17:48:57.795: sccp_dev_set_codecs: unsupported codec type 2
*Mar 3 17:48:57.795: sccp_xlate_voip_codec_type: payload 3 may be not supported or invalid payload type
*Mar 3 17:48:57.795: sccp_dev_set_codecs: unsupported codec type 3
*Mar 3 17:48:57.795: sccp_xlate_voip_codec_type: payload 4 may be not supported or invalid payload type
*Mar 3 17:48:57.795: sccp_dev_set_codecs: unsupported codec type 4
*Mar 3 17:48:57.795: sccp_xlate_voip_codec_type: payload 8 may be not supported or invalid payload type
*Mar 3 17:48:57.795: sccp_dev_set_codecs: unsupported codec type 8
*Mar 3 17:48:57.795: sccp_xlate_voip_codec_type: payload 9 may be not supported or invalid payload type
*Mar 3 17:48:57.799: sym_xapp_process_ccapi_events: minor is ZERO - should be non-zero for CCAPI event
*Mar 3 17:48:57.803: sym_xapp_xlate_ccapi_eve: Unsupported ccapi eve 2
*Mar 3 17:48:57.803: sym_xapp_process_ccapi_events: Unsupported ccapi eve_id 2
*Mar 3 17:48:57.911: sym_xapp_process_ccapi_events: minor is ZERO - should be non-zero for CCAPI event
*Mar 3 17:48:59.107: %SYS-5-CONFIG_I: Configured from console by sdag on vty0 (172.22.10.11)
*Mar 3 17:49:27.911: sccp_process_socket_connect_result: appl 86F5520C, soc_recv err 257, len -1, appl_type 6
*Mar 3 17:50:07.911: sccp_process_socket_connect_result: appl 86F5520C, soc_recv err 257, len -1, appl_type 6
*Mar 3 17:50:47.911: sccp_process_socket_connect_result: appl 86F5520C, soc_recv err 257, len -1, appl_type 6
*Mar 3 17:51:12.403: sym_xapp_process_ccapi_events: minor is ZERO - should be non-zero for CCAPI event
The voice ports seem to be ok:
vg204#show voice port summary
IN OUT
PORT CH SIG-TYPE ADMIN OPER STATUS STATUS EC
0/0 -- fxs-ls up dorm on-hook idle y
0/1 -- fxs-ls up dorm on-hook idle y
0/2 -- fxs-ls up dorm on-hook idle y
0/3 -- fxs-ls up dorm on-hook idle y
PWR FAILOVER PORT PSTN FAILOVER PORT
vg204#show sccp all
SCCP Admin State: UP
Gateway Local Interface: FastEthernet0/0
IPv4 Address: <local IP>
Port Number: 2000
IP Precedence: 5
User Masked Codec list: None
Call Manager: cucmsub, Port Number: 2000
Priority: N/A, Version: 7.0, Identifier: 2
Trustpoint: N/A
Call Manager: cucmpub, Port Number: 2000
Priority: N/A, Version: 7.0, Identifier: 1
Trustpoint: N/A
Alg_Phone Oper State: ACTIVE_IN_PROGRESS - Cause Code: TCP_CONN_ERROR
Active Call Manager: NONE
TCP Link Status: NOT_CONNECTED, Device Name: ANEBD5DF19C8000
Reported Max Streams: 1, Reported Max OOS Streams: 0
Supported Codec: rfc2833 dtmf, Maximum Packetization Period: 30
Supported Codec: g711ulaw, Maximum Packetization Period: 20
Supported Codec: g711alaw, Maximum Packetization Period: 20
Supported Codec: g729r8, Maximum Packetization Period: 220
Supported Codec: g729ar8, Maximum Packetization Period: 220
Supported Codec: g729br8, Maximum Packetization Period: 220
Supported Codec: ilbc, Maximum Packetization Period: 120
TCP Link Status: NOT_CONNECTED, Device Name: ANEBD5DF19C8001
TCP Link Status: NOT_CONNECTED, Device Name: ANEBD5DF19C8002
TCP Link Status: NOT_CONNECTED, Device Name: ANEBD5DF19C8003
AutoCfg_Virtual_Endpoint Oper State: ACTIVE_IN_PROGRESS - Cause Code: TCP_CONN_ERROR
TCP Link Status: CONNECT_PENDING, Device Name: ANEBD5DF19C8FFF
Reported Max Streams: 0, Reported Max OOS Streams: 0
SCCP Application Service(s) Statistics:
Device Name: ANEBD5DF19C8000, Service Type: Alg_Phone
Backlog Q Depth: 0 Socket -1 Appl 87B99DD0
TCP packets rx 0, tx 0
Unsupported pkts rx 0, Unrecognized pkts rx 0
Register tx 0, successful 0, rejected 0, failed 0
Unregister tx 0, successful 0
KeepAlive tx 0, successful 0, failed 0
OpenReceiveChannel rx 0, successful 0, failed 0
CloseReceiveChannel rx 0, successful 0, failed 0
StartMediaTransmission rx 0, successful 0, failed 0
StopMediaTransmission rx 0, successful 0, failed 0
PortReq rx 0
PortRes tx 0, successful 0, failed 0
PortClose rx 0
QosListen rx 0
QosPath rx 0
QosTeardown rx 0, send 0, recv 0, sendrecv 0
QosResvNotify tx 0, send 0, recv 0, sendrecv 0
QosErrorNotify tx 0, send 0, recv 0, sendrecv 0
err0 0, err1 0, err2 0, err3 0, err4 0, err5 0,
err6 0, err7 0, err8 0, err9 0, err10 0, err11 0,
err12 0
QosModify rx 0, send 0, recv 0, sendrecv 0
UpdateDscp rx 0
OpenMultiMediaReceiveChannel rx 0, successful 0, failed 0
CloseMultiReceiveChannel rx 0, successful 0, failed 0
StartMultiMediaTransmission rx 0, successful 0, failed 0
AddParticipant rx 0, successful 0, failed 0
ChangeParticipant rx 0, successful 0, failed 0
DropParticipant rx 0, successful 0, failed 0
MiscellaneousCommand rx 0, tx 0
FlowControlCommand rx 0, tx 0
Reset rx 0, successful 0, failed 0
MediaStreamingFailure rx 0
MediaStreamingFailure tx 0
Switchover 0, Switchback 0
Device Name: ANEBD5DF19C8001, Service Type: Alg_Phone
Backlog Q Depth: 0 Socket -1 Appl 87C0B8F8
PortReq rx 0
PortClose rx 0
QosListen rx 0
QosPath rx 0
err12 0
UpdateDscp rx 0
Device Name: ANEBD5DF19C8002, Service Type: Alg_Phone
Backlog Q Depth: 0 Socket -1 Appl 8872CF34
PortReq rx 0
PortClose rx 0
QosListen rx 0
QosPath rx 0
err12 0
UpdateDscp rx 0
Device Name: ANEBD5DF19C8003, Service Type: Alg_Phone
Backlog Q Depth: 0 Socket -1 Appl 8865FAD0
PortReq rx 0
PortClose rx 0
QosListen rx 0
QosPath rx 0
err12 0
UpdateDscp rx 0
Device Name: ANEBD5DF19C8FFF, Service Type: AutoCfg_Virtual_Endpoint
Backlog Q Depth: 0 Socket 4 Appl 87B6C23C
PortReq rx 0
PortClose rx 0
QosListen rx 0
QosPath rx 0
err12 0
UpdateDscp rx 0
CCM Group Identifier: 1
Description: None
Binded Interface: FastEthernet0/0
Associated CCM Id: 1, Priority in this CCM Group: 1
Associated CCM Id: 2, Priority in this CCM Group: 2
Registration Retries: 3, Registration Timeout: 10 sec
Keepalive Retries: 3, Keepalive Timeout: 30 sec
CCM Connect Retries: 3, CCM Connect Interval: 10 sec
Switchover Method: GRACEFUL, Switchback Method: GRACEFUL_GUARD
Switchback Interval: 10 sec, Switchback Timeout: 7200 sec
Signaling DSCP value: cs3, Audio DSCP value: ef
Total number of active session(s) 0, and connection(s) 0
Total number of active session(s) 0, connection(s) 0, and callegs 0
SCCP Application Service(s) Statistics Summary:
Total Conferencing Sessions: 0, Connections: 0
Total Transcoding Sessions: 0, Connections: 0
Total MTP Sessions: 0, Connections: 0
Total ALG-Phone Sessions: 0, Connections: 0
Total BRI-Phone Sessions: 0, Connections: 0
Total SCCP Sessions: 0, Connections: 0
Total Video Conferencing Sessions: 0, Connections: 0
Total Video Transcoding Sessions: 0, Connections: 0
Total active sessions 0, connections 0, rsvp sessions 0
No SCCP server info to display
vg204bom01#ping cucmpub
Sending 5, 100-byte ICMP Echos to cucmpub, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/1 ms
vg204bom01#ping cucmsub
Sending 5, 100-byte ICMP Echos to cucmsub, timeout is 2 seconds:
Publisher, Subscriber and VG are on the same subnet.
Thanks for any help.
Best Regards,
Daniel
Can you show a "show ccm-manager" output?
Also, I would verify you have "ip domain name company.org" configured since this will be tacked onto your SCCP ccm configuration if you have your device built in CUCM with your domain. VG204.company.org
5 Replies 5
George Sotiropoulos
Hello Daniel,
Have you assigned already a number to the corresponding FXS ports and reset the corresponding ports?
Hope the above helps,
gsotirop
Yes. I did that. And I double checked the Mac address.
vg204#show interfaces fastEthernet 0/0
FastEthernet0/0 is up, line protocol is up
Hardware is PQII_PRO_UEC, address is 00eb.d5df.19c8 (bia 00eb.d5df.19c8)
Internet address is <vg204 IP address>/24
MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
On the Port I added also a DN, just to make sure, it's not the same behavior like with SIP phones ...
The device seems to be right on the CUCM:
vg204#show stcapp device summary
Total Devices: 4
Total Calls in Progress: 0
Total Call Legs in Use: 0
Port Device Device Call Dev Directory Dev
Identifier Name State State Type Number Cntl
0/0 ANEBD5DF19C8000 OOS UNREGISTERED ALG Not Avail UNKN
0/1 ANEBD5DF19C8001 OOS UNREGISTERED ALG Not Avail UNKN
0/2 ANEBD5DF19C8002 OOS UNREGISTERED ALG Not Avail UNKN
0/3 ANEBD5DF19C8003 OOS UNREGISTERED ALG Not Avail UNKN
Best Regards,
Daniel
When I configure VG204s I get the MAC address by doing a show sccp
Hi all
Thanks a lot for your answers.
I don't really know what was wrong. I copied the config back on after a factory reset and the vg registerd immediatly.
Thanks a lot and have a nice day.
