VG224 Error w/ stcapp
b0otable7
I am trying to set up a vg224 to work with CUCM.
I was following a config
1. enable
2. configure terminal
3. stcapp ccm-group group-id
4. stcapp
5. stcapp feature access-code
6. stcapp feature speed-dial
7. voice-port slot-number/port
8. timeouts initial seconds
Anway at step 4 I get:
STCAPP: Config error: SCCP stack not configured... exiting stcapp shutdown initiated... waiting for calls to clear.
Any Ideas what the problem might be, or how to fix it?
frlindse
Hi Thomas,
Are the fXS ports registered to CUCM currently?  You will haver to shutdown sccp to make any changes.  What is the IOS version and the version of CUCM?
I needed to enable IP routing
alonsosolorzano
Hi Thomas
I got the same Error,
My Version Software (vg224-I6S-M), Version 12.4(24)T5
My config
stcapp ccm-group 1
prefix #
call forward all 78
call forward cancel 79
pickup local 75
pickup group 74
interface FastEthernet0/0
ip address 192.168.100.X 255.255.255.0
duplex auto
speed auto
voice-port 2/0
timeouts ringing infinity
voice-port 2/1
mgcp fax t38 ecm
sccp local FastEthernet0/0
sccp ccm 192.168.100.x identifier 3 version 7.0
sccp ccm 192.168.100.x identifier 1 version 7.0
sccp
sccp ccm group 1
associate ccm 1 priority 1
associate ccm 3 priority 3
dial-peer voice 1 pots
service stcapp
port 2/0
dial-peer voice 2 pots
service stcapp
port 2/1
VG-MCVG224-01# sh sccp all
SCCP Admin State: UP
Gateway Local Interface: FastEthernet0/0
        IPv4 Address: 192.168.100.x
        Port Number: 2000
IP Precedence: 5
User Masked Codec list: None
Call Manager: 192.168.100.11, Port Number: 2000
                Priority: N/A, Version: 7.0, Identifier: 3
                Trustpoint: N/A
Call Manager: 192.168.100.x, Port Number: 2000
                Priority: N/A, Version: 7.0, Identifier: 1
                Trustpoint: N/A
SCCP application services(dspfarm profiles) are not enabled
or haven't associated to SCCP CCM group
CCM Group Identifier: 1
Description: None
Binded Interface: None
Associated CCM Id: 1, Priority in this CCM Group: 1
Associated CCM Id: 3, Priority in this CCM Group: 3
Registration Retries: 3, Registration Timeout: 10 sec
Keepalive Retries: 3, Keepalive Timeout: 30 sec
CCM Connect Retries: 3, CCM Connect Interval: 10 sec
Switchover Method: GRACEFUL, Switchback Method: GRACEFUL_GUARD
Switchback Interval: 10 sec, Switchback Timeout: 7200 sec
Signaling DSCP value: cs3, Audio DSCP value: ef
Total number of active session(s) 0, and connection(s) 0
Total number of active session(s) 0, connection(s) 0, and callegs 0
SCCP Application Service(s) Statistics Summary:
Total Conferencing Sessions: 0, Connections: 0
Total Transcoding Sessions: 0, Connections: 0
Total MTP Sessions: 0, Connections: 0
Total ALG-Phone Sessions: 0, Connections: 0
Total BRI-Phone Sessions: 0, Connections: 0
Total SCCP Sessions: 0, Connections: 0
Total active sessions 0, connections 0, rsvp sessions 0
No SCCP server info to display
VG-MCVG224-01#VG-MCVG224-01#
VG-MCVG224-01#sh stcapp feature codes
    malicious call ID (MCID) ***
    prefix #
    call forward all #78
    call forward cancel #79
    pickup local group #75
    pickup different group #74
    pickup direct #6
    meetme-conference #5
  stcapp feature speed-dial disabled
stcapp call-control mode is standard mode
VG-MCVG224-01#
I can't activate the STCAPP !!!
Hola  que tal     tengo el mismo error en el  VG   lo que  hice   y ya me funciono  fue lo siguiente :
1.- negue los servicios  de sccp  y los di de baja
2.- los volvi a crear  para que se firmara  con el CUCM
3.-  volvia generar los servicios de stcapp ccm-group 1
 stcapp
4.- DONE !!!!
funciono mi  vg se firma  y despues de  haberlo hecho   ya funciono correctamente
INTENTENLO
