VG224 Issue with UCM7 & MGCP
sohaildxbfze
Hi all,
m into crazy issue with mgcp VG224 some ports not showing correct status, when i dial port it plays busy infact port is available.Even no output from debug vpm signal.This is happeinng on some ports on same VG.Resetting @ VG & UCM doesnt solve it,even reload of VG224.
VG224 IOS ver:slot0:vg224-i6s-mz.124-5b.bin
UCM ver:7.0.2.20000-5
MGCP statistics are follows
VOIR01VG22406#sh mgcp stat
UDP pkts rx 662, tx 668
Unrecognized rx pkts 0, MGCP message parsing errors 0
Duplicate MGCP ack tx 0, Invalid versions count 0
CreateConn rx 13, successful 13, failed 0
DeleteConn rx 17, successful 13, failed 4
ModifyConn rx 0, successful 0, failed 0
DeleteConn tx 0, successful 0, failed 0
NotifyRequest rx 80, successful 74, failed 6
AuditConnection rx 0, successful 0, failed 0
AuditEndpoint rx 60, successful 60, failed 0
RestartInProgress tx 65, successful 65, failed 0
Notify tx 422, successful 422, failed 0
ACK tx 160, NACK tx 15
ACK rx 487, NACK rx 0
IP address based Call Agents statistics:
IP address 10.103.1.12, Total msg rx 662,
successful 647, failed 15
System resource check is DISABLED. No available statistic
DS0 Resource Statistics
Utilization: 0.00 percent
Total channels: 19
Addressable channels: 19
Inuse channels: 0
Disabled channels: 0
Free channels: 19
Below is VG224 config::::
resource policy
voice-card 0
interface FastEthernet0/0
ip address x.x.x.x x.x.x.x
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
ip route 0.0.0.0 0.0.0.0 x.x.x.1
control-plane
voice-port 2/0
idle-voltage low
voice-port 2/1
voice-port 2/2
voice-port 2/3
voice-port 2/4
voice-port 2/5
voice-port 2/6
voice-port 2/7
voice-port 2/8
voice-port 2/9
voice-port 2/10
voice-port 2/11
voice-port 2/12
voice-port 2/13
voice-port 2/14
voice-port 2/15
voice-port 2/16
voice-port 2/17
voice-port 2/18
voice-port 2/19
voice-port 2/20
voice-port 2/21
voice-port 2/22
voice-port 2/23
ccm-manager redundant-host x.x.x.13 x.x.x.11
ccm-manager mgcp
ccm-manager music-on-hold
ccm-manager config server x.x.x.11
ccm-manager config
mgcp
mgcp call-agent x.x.x.12 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
no mgcp package-capability res-package
mgcp package-capability sst-package
no mgcp package-capability fxr-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 inhibit
mgcp rtp payload-type g726r16 static
mgcp profile default
dial-peer voice 99920 pots
service mgcpapp
port 2/0
dial-peer voice 99921 pots
service mgcpapp
port 2/1
dial-peer voice 99922 pots
service mgcpapp
port 2/2
dial-peer voice 99923 pots
service mgcpapp
port 2/3
dial-peer voice 99925 pots
service mgcpapp
port 2/5
dial-peer voice 99927 pots
service mgcpapp
port 2/7
dial-peer voice 999210 pots
service mgcpapp
port 2/10
dial-peer voice 999215 pots
service mgcpapp
port 2/15
dial-peer voice 999223 pots
service mgcpapp
port 2/23
dial-peer voice 999218 pots
service mgcpapp
port 2/18
dial-peer voice 999219 pots
service mgcpapp
port 2/19
dial-peer voice 999222 pots
service mgcpapp
port 2/22
dial-peer voice 99926 pots
service mgcpapp
port 2/6
dial-peer voice 99924 pots
service mgcpapp
port 2/4
dial-peer voice 99929 pots
service mgcpapp
port 2/9
dial-peer voice 999216 pots
service mgcpapp
port 2/16
dial-peer voice 999211 pots
service mgcpapp
port 2/11
dial-peer voice 999212 pots
service mgcpapp
port 2/12
dial-peer voice 999213 pots
service mgcpapp
port 2/13
Any help is highly appreciated!!!!!!!
MGCP isn't the best solution with VG224
SCCP with VG224 is more recommended and stable beside the more features you'll benefit from it as suppplementary services for example
thanks
6 Replies 6
thanks
Are you sure you have all the correct dial peers? If you have 24 phones on this system, not all of them are registered.
-nick
It same seem stupid but have you rung the port with a phone in it? I`ve had it before where I got fastbusy until I plugged a phone in the port
ofcourse , i rang the phone,, infact faxes are connect3ed to all vg ports
You should listen to the advice by hythamhadad, switch away from MGCP and you shall be fine.
We had the exact same issue on several VG224. Turned out to be an IOS bug resolved in 12.4(24)T. Since upgrading to this release, we have not had this happen again. Prior to this IOS upgrade, only resolution was a to reload the VG224. A reset in Call Manager for a given port would resolve issue for a sort time some of the time.
