VG224 registration ISSUE with CUCM 7
wilsonsant
Level 6
Level 6
Hi Guys,
I need to invert the registration VG224 of CUCM Publisher to CUCM Subscriber. The previous configuration was:
sccp local FastEthernet0/0
sccp ccm 10.20.4.230 identifier 1 version 7.0
sccp ccm 10.20.4.231 identifier 2 version 7.0
sccp
sccp ccm group 1
 bind interface FastEthernet0/0
 associate ccm 1 priority 1
 associate ccm 2 priority 2
Now I putted:
sccp ccm 10.20.4.231 identifier 1 version 7.0
sccp ccm 10.20.4.230 identifier 2 version 7.0
sccp
sccp ccm group 1
 associate ccm 2 priority 1
 associate ccm 1 priority 2
but, didn´t worked. Are another configuration to change? In the CUCM I need to do changes?
Wilson
2 Accepted Solutions
Gordon Ross
Level 9
Level 9
You need to change the CUCM Group/Device Pool for the VG224 ports.
GTG
Please rate all helpful posts.
Original:
sccp ccm 10.20.4.230 identifier 1 version 7.0  <--- This is ID #1
sccp
sccp ccm group 1
 associate ccm 1 priority 1  <--- This says to use ID #1 first
Now I putted:
sccp ccm 10.20.4.230 identifier 2 version 7.0  <--- This is ID #2
sccp
sccp ccm group 1
 associate ccm 2 priority 1  <--- This says to use ID #2 first
As you can see in the original config, ID #1 is used first which is 10.20.4.230.
In the changed config, ID #2 is used first which is also 10.20.4.230
End result is that 10.20.4.230 is used in either case.
sccp
sccp ccm group 1
Now I putted:
sccp
sccp ccm group 1
- See more at: https://supportforums.cisco.com/discussion/12512316/vg224-registration-issue-cucm-7#sthash.SdUNrnfj.dpuf
sccp
sccp ccm group 1
Now I putted:
sccp
sccp ccm group 1
9 Replies 9
Gordon Ross
Level 9
Level 9
GTG
Hi Gordon,
Thanks a lot for Your contact. This configuration that You mentioning is of CUCM side?
Wilson
Yes, in CCMAdmin.
GTG
Also, the changes to the SCCP group did not change anything.
You started with CCM ID 1 (10.20.4.230) as the first CCM to try to register with.
Then you changed it to CCM ID 2 is the first CCM to use but at the same time you changed CCM ID 2 = 10.20.4.230. The end result is 10.20.4.230 is used first for both situations. You can change the IP address assigned to an ID or the priority of the ID but if you change both you end up back where you started.
Hi kkoeper12,
I am sorry, but, I didn´t understand, stay confuse your explanation.
Wilson
Original:
sccp
sccp ccm group 1
Now I putted:
sccp
sccp ccm group 1
sccp
sccp ccm group 1
Now I putted:
sccp
sccp ccm group 1
sccp
sccp ccm group 1
Now I putted:
sccp
sccp ccm group 1
Hi Gordon and kkoeper12,
I changed the configuration (reverse put ccm subscriber priority 1 and ccm publisher priority 2) and didn´t work. I erase the configuration and include only cucm subscriber, but, didn´t worked too. The analog phone not register in CUCM.
Wilson
Hi Gordon and Kkoeper12,
Today I did again the configuration (erase the parameters about sccp and create) and worked.
Thanks a lot for your help,.
Wilson
Hi kkoeper12,
In the really the configuration actuall is:
sccp ccm 10.224.4.251 identifier 2 version 7.0
sccp ccm 10.224.4.252 identifier 1 version 7.0
sccp
sccp ccm group 1
Wilson
