VG248 disconnect calls
jamesleewright
I recently upgraded the software on a VG248 to 1.3(2)ES2 and now calls on a analog push button elevator phone wont work. It calls fine but when other end user hangs up does not disconnect and you hear a fast busy. It disconnects with previous software so I failed back.
Does anyone know what new setting in telephony advanced will disconnect the call in this scenrio? thanks
5 Replies 5
Bruno Rangel
Hi James
You can try Choosing a Call Supervision Method, chose between several different call supervision methods:
• None— no call supervision
•Drop loop current — indicates to an analog device that the remote caller has hung up. For example, if a user calls someone with an answering machine, leaves a message, and hangs up, disconnect supervision is the electrical state that briefly drops the loop current and indicates to the answering machine that the caller has hung up.
•Reverse polarity — useful for billing systems. When a call connects, polarity reverses, indicating that charges begin to accrue. When the call goes down, polarity reverses back to normal and charges stop.
Follow these steps to choose a call supervision method on a per port basis:
Step 1 From the main menu, choose Configure.
Step 2 Choose Telephony.
Step 3 Choose Port specific parameters.
Step 4 Use the arrow keys to select the port to configure and press Enter.
Step 5 Choose Call supervision method.
Step 6 Choose one of the following options:
•none
•drop loop current
•reverse polarity
Please rate this post
Cheers
Bruno Rangel
Please remember to rate helpful responses using the star bellow and identify helpful or correct answers
thanks I tried that, using a spare VG, but it does not change anything when the other phone hangs up, fast busy.,
the working vg's port is set to call supervison method none
thanks
You mean no one these Call Supervision Method works?
The other works VG248 have the same version?
Cheers
Bruno Rangel
that is correct no matter what i chose for call supervision method I get a continuous fast busy after the otherline disconnects
thanks!
Rob Huffman
Hi James,
I would look at the Advanced setting referenced below;
CSCse77040            Bug Details
PLAR behavior inconsistent with VG248 ph when called party ends the call
Symptom:
PLAR behavior incocnsistent with VG248 phone when called party ends the call
before calling party
Conditions:
Ends the call first in called party and then onhook the VG248 phone.
Workaround:
None.
Further problem Description:
Utilize the "Busy out off hook ports" replacement paramater, "reject
softkey". It allows for control of port busy signaling by using a soft key.
To use this feature, please make sure that the Call Manager is running either
the latest 4.1(3) service pack or 4.2(1)sr1 or a later 4.2 version.
To activate "Reject Softkey mode, use the console menu to set "Port busy
signaling" to reject soft key.
Configure->Telephony->Advanced settings->Port busy signaling = reject soft key
Status Status
Terminated
Severity Severity
3 - moderate
Last Modified Last Modified
Any Time
Product Product
Cisco VG Series Gateways
Technology Technology
1st Found-In 1st Found-in
1.3(1)ES8.2
Here's the Readme for your new vesrion;
Cisco VG248 1.3(2)ES3 Release Notes
This engineering special image resolves one issue CSCso07174
Problem Description
With VG248 version 1.3(2), when port busy signaling is set to reject softkey and if a terminating
analog phone is hang up first, then incoming calls to this analog port will be rejected.
Workaround/Solution
An upgrade to engineering special build 1.3(2)ES3 is required.
DDTS Information
CSCso07174 VG248 will not process call inbound if Port busy signaling invoked
Cheers!
Rob
"And if I should fall behind
Wait for me" - Springsteen
