VG350 mgcp pulse
seva
I have CUCM 12.5 and Gateway VG350. VG350 registered by protocol MGCP. Pulse dialing does not work.
In what mode does the pulse dialing work?
seva
Registration with MGCP did not solve the problem.
Pulse dialing works with SCCP registration
With pulse dialling do you refer to call with a rotary dial telephone? If so I’m not sure if that’s supported by anything these days.
Response Signature
seva
Any specific reason for why you don’t have it setup with SCCP then? What’s the reason for why you’d want to use MGCP if this would work with SCCP?
Response Signature
Used SCCP. The solution works. I did not find any information that this functionality does not work on MGСP. Perhaps my case will save someone time.
