VIC2 compatibility
federico_tv
Could anybody please confirm me if BRI cards :
VIC2-2BRI- NT/TE
are compatible with old 1751V and 1760 routers ??
Is there any particular Voice IOS they are compatible starting from ??
Thank you very much.
5 Replies 5
Rob Huffman
Hi Federico;
Check;
Platform Support
Cisco IOS Support 11751, 1760326002600XM/2650XM36204, 3640 23660 22691, 3725, 3745VG200
VIC-2BRI-S/T-TE 2-Port ISDN BRI VIC, S/T interface, TENot Supported12.0(2)XD, 12.0(3)T, 12.0XK, 12.1(1), 12.1(1)T, 12.2(1), 12.2(2)T,12.2(2)XT, 12.2(11)YT, 12.3(1)All Cisco IOS Software Versions 12.0(7)XK, 12.1(1)T, 12.1(5)YB, 12.1(5)YD, 12.2(1), 12.2(2)T, 12.2(2)XT, 12.2(11)YT, 12.2(15)ZJ, 12.3(1), 12.3(2)TAll VersionsAll Cisco IOS Software Versions
VIC-2BRI-NT-TE 2-Port ISDN BRI VIC, S/T interface, NT, TEAll Versions12.1(3)XI, 12.1(5)T,12.1(5)YB, 12.1(5)YD, 12.2(1), 12.2(2)T, 12.2(2)XT, 12.2(11)YT, 12.3(1)12.2(8)T1,12.2(11)T, 12.2(11)YT, 12.2(12), 12.2(15)ZJ, 12.3(1), 12.3(2)T12.1(3)XI, 12.1(5)T, 12.1(5)YB, 12.1(5)YD, 12.2(1), 12.2(2)T, 12.2(2)XT, 12.2(11)YT, 12.2(15)ZJ, 12.3(1)12.1(3)XI, 12.1(5)T, 12.1(5)YB, 12.1(5)YD, 12.2(1), 12.2(2)T, 12.2(2)XT, 12.2(11)YT, 12.2(15)ZJ, 12.3(1)12.2(11)YT, 12.2(13)T, 12.2(15)ZJ, 12.3(1), 12.3(2)T, 12.3(4)XD12.1(5)T, 12.2(1), 12.2(2)T, 12.3(1)
VIC2-2BRI-NT-TE 2-Port ISDN BRI VIC, S/T interface, NT, TE12.2(15)ZL, 12.3(2)XA, 12.3(2)XC, 12.3(2)XE, 12.3(4)T, 12.3(5)Not Supported12.2(15)ZJ, 12.3(4)T12.2(15)ZJ, 12.3(4)T (Not supported for Cisco 3620.4)12.2(15)ZJ, 12.3(4)T12.2(15)ZJ, 12.3(4)T, 12.3(4)XDNot Supported
1 Voice requires a Cisco IOS Software Voice feature set on the 1700 series router, and a Cisco IOS Software Plus feature set on the 2600/3600 series router.
2 Voice is not supported on the 3631 router.
3Cisco 1750 router platforms do not support the BRI VICs.
4Cisco 3620 series routers do not support the VIC2-2BRI-NT-TE cards.
From;
http://www.cisco.com/c/en/us/support/docs/voice/digital-ccs/7960-2isdn-bri-vic.html
Cheers!
Rob
Hi Federico,
[+5] to Rob.
you can also refer the links
http://www.cisco.com/c/en/us/support/docs/voice/digital-ccs/15415-bri-voice-port-cfg.html
regds,
aman
Very satisfactory infos,
Thank you both !!
A last question :
How do I calculate the amount of PVDM needed per VIC card ??
I have to install 2x    vic(2) 2 BRI  cards, which PVDM I need ?
You can us e DSP Calculator
http://www.cisco.com/web/applicat/dsprecal/dsp_calc.html
regds,
aman
FYI I have a customer who runs these cards in 2901s using ios 15.4(3)M5 which is not listed in the Cisco compatiblity guidelines but still works.
