07-06-2025 10:19 PM
Dear Team,
video calls are not working on cisco cme (cisco isr 4431). we are using cisco 8865 phones and registered in cisco 4331 Voice gateway.
Please do the needful
07-08-2025 03:18 AM
Did video calls work before? Is there a specific scenario where video calls don't work?
07-08-2025 09:24 PM
No. First time we configured Video Phones in cisco 4331
07-08-2025 07:06 AM
Video calls on Cisco 8865 phones with ISR 4431 CME often don’t work due to a few key reasons:
Insufficient bandwidth or missing QoS settings for video traffic.
Unsupported or misconfigured video codecs (like H.264) on the ISR or CME.
Video calling not enabled or set up properly on phones or CME.
Firewalls or access controls blocking video signaling or media ports.
Outdated or incompatible IOS on ISR or phone firmware.
Verifying and addressing these areas typically resolves video call problems.
07-08-2025 09:26 PM
Thank you wajid for key reasons. where should i configure h264 codec. unable to assign in voice register pool.
07-08-2025 10:35 PM
You’ll need to use a codec list where you put all the codecs that you intend to use and then use that on the CME phone configuration instead of individual codecs.
07-14-2025 06:02 AM
Dear Roger sir,
Do I need to create a "voice class codec list"? And where should I apply in my config.
07-14-2025 06:15 AM
Yes you do. It should be assigned to the phone device configuration in CME.
07-14-2025 09:51 PM
Dear Roger ji,
I have created a codec list and applied it in the voice register pool, but I'm not having any luck. Video calls are not working, only voice calls are working. below is the config.
voice class codec 1
codec preference 1 g711ulaw
video codec h264
voice register pool 78
busy-trigger-per-button 2
id mac 08CC.A785.3F3A
type 8865
number 1 dn 78
dtmf-relay cisco-rtp
voice-class codec 1
camera
video
voice register pool 79
id mac 08CC.A785.5C2C
type 8865
number 1 dn 79
voice-class codec 1
camera
video
07-14-2025 10:26 PM
07-14-2025 11:16 PM
There is simply too much clutter in your debug output to make it easy to identify the called attempts. For example there is a bunch of phone registration and unregistration events that takes up a significant portion of your debug data. Please collect a clean output that contains just the call attempts and please outline the called, calling number and time of each call so we can easily identify each call attempt.
What I do see in the shared data is this.
Sent: SIP UDP message from 172.17.40.8:5060 to 172.17.40.95:5060
SIP/2.0 484 Address Incomplete
That would indicate that the dialed number is incomplete and more numbers needs to be entered on the keypad.
07-15-2025 12:35 AM
Dear Roger,
Please find the clean output. called number 167, and the calling number is 168.
Jul 15 06:30:22.717: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:167@172.17.40.8;user=phone SIP/2.0
Via: SIP/2.0/UDP 172.17.40.177:5060;branch=z9hG4bK1df8d283
From: "vd-2" <sip:168@172.17.40.8>;tag=08cca7855c2c0049010fa70d-0c0a62ad
To: <sip:167@172.17.40.8>
Call-ID: 08cca785-5c2c0007-10d2a6b1-32b93f62@172.17.40.177
Max-Forwards: 70
Session-ID: 21b45ef100105000a00008cca7855c2c;remote=00000000000000000000000000000000
Date: Tue, 15 Jul 2025 06:30:21 GMT
CSeq: 101 INVITE
User-Agent: Cisco-CP8865/14.1.1
Contact: <sip:3339B66C-20F5@172.17.40.177:5060;transport=udp>;+u.sip!devicename.ccm.cisco.com="SEP08CCA7855C2C";video
Expires: 180
Accept: application/sdp
Allow: ACK,BYE,CANCEL,INVITE,NOTIFY,OPTIONS,REFER,REGISTER,UPDATE,SUBSCRIBE,INFO
Remote-Party-ID: "vd-2" <sip:168@172.17.40.8>;party=calling;id-type=subscriber;privacy=off;screen=yes
Supported: replaces,join,sdp-anat,norefersub,resource-priority,extended-refer,X-cisco-callinfo,X-cisco-serviceuri,X-cisco-escapecodes,X-cisco-service-control,X-cisco-srtp-fallback,X-cisco-monrec,X-cisco-config,X-cisco-sis-7.0.0,X-cisco-xsi-8.5.1
Allow-Events: kpml,dialog
Recv-Info: conference
Recv-Info: x-cisco-conference
Content-Length: 1176
Content-Type: application/sdp
Content-Disposition: session;handling=optional
v=0
o=Cisco-SIPUA 18417 0 IN IP4 172.17.40.177
s=SIP Call
b=AS:4064
t=0 0
m=audio 19372 RTP/AVP 0 8 116 18 101
c=IN IP4 172.17.40.177
b=TIAS:64000
a=rtpmap:0 PCMU/8000
a=rtpmap:8 PCMA/8000
a=rtpmap:116 iLBC/8000
a=fmtp:116 mode=20
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
a=sendrecv
m=video 27780 RTP/AVP 100 126 97
b=TIAS:4000000
a=rtpmap:100 H264/90000
a=fmtp:100 profile-level-id=640C16;packetization-mode=1;level-asymmetry-allowed=1;max-mbps=108000;max-fs=3600;max-rcmd-nalu-size=256000
a=imageattr:* recv [x=800,y=480,q=0.60] [x=1280,y=720,q=0.50]
a=rtpmap:126 H264/90000
a=fmtp:126 profile-level-id=428016;packetization-mode=1;level-asymmetry-allowed=1;max-mbps=108000;max-fs=3600;max-rcmd-nalu-size=256000
a=rtpmap:97 H264/90000
a=fmtp:97 profile-level-id=428016;packetization-mode=0;level-asymmetry-allowed=1;max-mbps=108000;max-fs=3600;max-rcmd-nalu-size=256000
a=rtcp-fb:* nack pli
a=rtcp-fb:* ccm fir
a=rtcp-fb:* ccm tmmbr
a=sendrecv
Jul 15 06:30:22.724: //5984845/05279FEB971B/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
--More--
Date: Tue, 15 Jul 2025 06:30:22 GMT
CSeq: 101 INVITE
Allow-Events: telephone-event
Server: Cisco-SIPGateway/IOS-17.6.1a
Session-ID: 00000000000000000000000000000000;remote=21b45ef100105000a00008cca7855c2c
Content-Length: 0
Jul 15 06:30:22.733: //5984847/05279FEB971B/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:167@172.17.40.227:5060 SIP/2.0
Via: SIP/2.0/UDP 172.17.40.8:5060;branch=z9hG4bK3DE4D1220
Remote-Party-ID: "vd-2" <sip:168@ap.ims.airtel.in>;party=calling;screen=yes;privacy=off
From: "vd-2" <sip:168@ap.ims.airtel.in>;tag=7AB0342B-7DF
To: <sip:167@172.17.40.227>
Call-ID: 5299BB9-607C11F0-9721A909-A8177645@ap.ims.airtel.in
Supported: 100rel,timer,resource-priority,replaces
Min-SE: 1800
Cisco-Guid: 0086482923-1618743792-2535172361-2820109893
User-Agent: Cisco-SIPGateway/IOS-17.6.1a
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Timestamp: 1752561022
Contact: <sip:168@172.17.40.8:5060>
Expires: 180
Max-Forwards: 69
Content-Disposition: session;handling=required
Content-Length: 329
v=0
o=CiscoSystemsSIP-GW-UserAgent 7384 4629 IN IP4 172.17.40.8
s=SIP Call
c=IN IP4 172.17.40.8
t=0 0
m=audio 32072 RTP/AVP 0 121 19
a=rtpmap:121 frf-dialed-digit/8000
a=fmtp:121 0-15
a=rtpmap:19 CN/8000
a=ptime:20
m=video 0 RTP/AVP 255
b=TIAS:512000
Jul 15 06:30:22.738: //5984847/05279FEB971B/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
Session-ID: 41e1309000105000a00008cca7853f3a;remote=21b45ef100105000a00008cca7855c2c
CSeq: 101 INVITE
Server: Cisco-CP8865/11.0.1
Contact: <sip:33135A21-53@172.17.40.227:5060;transport=udp>;+u.sip!devicename.ccm.cisco.com="SEP08CCA7853F3A";video
--More--
Content-Length: 0
Jul 15 06:30:22.897: //5984847/05279FEB971B/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 180 Ringing
To: <sip:167@172.17.40.227>;tag=08cca7853f3a00060b3efeb5-540df836
CSeq: 101 INVITE
Remote-Party-ID: "vd-1" <sip:167@172.17.40.8>;party=called;id-type=subscriber;privacy=off;screen=yes
Content-Length: 0
Jul 15 06:30:22.899: //5984845/05279FEB971B/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 180 Ringing
To: <sip:167@172.17.40.8>;tag=7AB034D2-224E
CSeq: 101 INVITE
Remote-Party-ID: "vd-1" <sip:167@ap.ims.airtel.in>;party=called;screen=yes;privacy=off
Contact: <sip:33135A21-53@172.17.40.8:5060>
Content-Length: 0
Jul 15 06:30:27.578: //5984847/05279FEB971B/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
Date: Tue, 15 Jul 2025 06:30:26 GMT
CSeq: 101 INVITE
Content-Length: 206
v=0
o=Cisco-SIPUA 13932 0 IN IP4 172.17.40.227
s=SIP Call
t=0 0
m=audio 22280 RTP/AVP 0
c=IN IP4 172.17.40.227
b=TIAS:64000
a=sendrecv
c=IN IP4 0.0.0.0
Jul 15 06:30:27.582: //5984847/05279FEB971B/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:33135A21-53@172.17.40.227:5060;transport=udp SIP/2.0
Via: SIP/2.0/UDP 172.17.40.8:5060;branch=z9hG4bK3DE4E191F
Max-Forwards: 70
CSeq: 101 ACK
Session-ID: 21b45ef100105000a00008cca7855c2c;remote=41e1309000105000a00008cca7853f3a
Content-Length: 0
Jul 15 06:30:27.586: //5984845/05279FEB971B/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
--More--
CSeq: 101 INVITE
Contact: <sip:167@172.17.40.8:5060>
Supported: replaces
Supported: timer
Content-Length: 248
v=0
o=CiscoSystemsSIP-GW-UserAgent 7456 7292 IN IP4 172.17.40.8
s=SIP Call
t=0 0
m=audio 32078 RTP/AVP 0
a=ptime:20
m=video 0 RTP/AVP 100
b=TIAS:512000
Jul 15 06:30:27.595: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:167@172.17.40.8:5060 SIP/2.0
Via: SIP/2.0/UDP 172.17.40.177:5060;branch=z9hG4bK195d1d16
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
Jul 15 06:30:38.867: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
BYE sip:167@172.17.40.8:5060 SIP/2.0
Via: SIP/2.0/UDP 172.17.40.177:5060;branch=z9hG4bK4816f7e4
Max-Forwards: 70
Date: Tue, 15 Jul 2025 06:30:38 GMT
CSeq: 102 BYE
Content-Length: 0
Jul 15 06:30:38.871: //5984845/05279FEB971B/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 102 BYE
Reason: Q.850;cause=16
Content-Length: 0
Jul 15 06:30:38.871: //5984847/05279FEB971B/SIP/Msg/ccsipDisplayMsg:
Sent:
BYE sip:33135A21-53@172.17.40.227:5060;transport=udp SIP/2.0
Via: SIP/2.0/UDP 172.17.40.8:5060;branch=z9hG4bK3DE4F135F
Max-Forwards: 70
Timestamp: 1752561038
CSeq: 102 BYE
Content-Length: 0
Jul 15 06:30:39.024: //5984847/05279FEB971B/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
--More--
CSeq: 102 BYE
Content-Length: 0
Jul 15 06:30:50.715: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
REGISTER sip:172.17.40.8 SIP/2.0
Via: SIP/2.0/UDP 172.17.40.177:5060;branch=z9hG4bK6f656006
From: <sip:168@172.17.40.8>;tag=08cca7855c2c004a23b0a170-557df242
To: <sip:168@172.17.40.8>
Call-ID: 08cca785-5c2c0002-38423ac0-1ca1fca7@172.17.40.177
Max-Forwards: 70
Session-ID: 9980499f00105000a00008cca7855c2c;remote=00000000000000000000000000000000
Date: Tue, 15 Jul 2025 06:30:49 GMT
CSeq: 161 REGISTER
Contact: <sip:3339B66C-20F5@172.17.40.177:5060;transport=udp>;+sip.instance="<urn:uuid:00000000-0000-0000-0000-08cca7855c2c>";+u.sip!devicename.ccm.cisco.com="SEP08CCA7855C2C";+u.sip!model.ccm.cisco.com="36225";video
--More--
Content-Length: 0
Expires: 3600
Jul 15 06:30:50.717: //5984862/15D7A1199735/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:168@172.17.40.8>;tag=7AB0A17B-69F
Date: Tue, 15 Jul 2025 06:30:50 GMT
CSeq: 161 REGISTER
Supported: X-cisco-cme-sis-9.0.0
Supported: X-cisco-srtp-fallback
Contact: <sip:168@172.17.40.177:5060>;expires=120
Expires: 120
Content-Length: 0
VTZ_ISR_4331#
07-15-2025 07:05 AM - edited 07-15-2025 10:39 PM
For future reference, it’s so much easier to work on the debug text if you put the output in a text file rather than directly in the inline text in the reply. Even so I looked through the text and wonder what is 172.17.40.227? It looks like the call might have gone via PSTN?
07-15-2025 09:09 PM
IP 172.17.40.227 is the VOIP phone (called no 167) IP address sir
07-21-2025 12:11 AM
please do the needful.
