05-09-2017 12:29 AM - edited 03-17-2019 10:16 AM
Dear Support,
I am using CUCM 10 , Voice Gateway - 2921, protocol H.323
The problem is that when i am dialing an international call , i am unable to input an digits to select options.
International calling dial-peer
dial-peer voice 20 pots
description ##-International-Calls-##
tone ringback alert-no-PI
translation-profile outgoing OUT
destination-pattern 900T
direct-inward-dial
port 0/0/0:15
prefix 00
Note: with mobile dial-peer i am able to input digits.
Mobile dial-peer
dial-peer voice 1 pots
destination-pattern 905[0256].......
direct-inward-dial
port 0/0/0:15
forward-digits 10
I would appreciate if some one could help me solve this issue.
05-09-2017 01:12 AM
Replicate the Issue and collect the debugs
debug voip rtp session named-event
debug h245 asn1
Also Share you Complete Configuration , All the dial-peers.
We need to Verify What Was DTMF Method Negotiated.
haris
05-09-2017 06:22 AM
Also, post all of your dial-peers as each call has 2 legs thus 2 dial-peers, in your example first a voip dialpeer is matched and you need to have one with proper DTMF method, otherwise default dial-peer 0 is used.
