Showing results forĀ
Search instead forĀ
Did you mean:Ā
voice gateway system is hacked and make many toll calls
tinafaye87796
I am a newbie in cisco internal audit.
our company voice gateway system is hacked and make many toll calls.
I found our internet gateway router (cisco 3925)has a unknown suspicious username and some ip local pool...
we are auditing the system. I am quite confused how our system is hacked. may anyone can help? my questions are:
  1. How a hacker can create a account in my internet gateway router ? any known Vulnerability?
  2. Why the hacker use the vpn ?
  3. How hacker can instruct the voice gateway after login the internet router?
THX!
Best regards,
Tina
balaji.bandi
it all depends on your setup and how you secured your dial plan.
BB
George Sotiropoulos
It is really important to fain knowledge on network segmentation and security. To answer your questions, someone should know your environment (in terms of networking) but also your dial-plan.
George
Please Rate Posts (by clicking on Star) and/or Mark Solutions as Accepted, when applies
