voice hunt-group xfer issue.
keithtuttle
I am using a CME with a sip trunk to an asteriskNow system for auto attendant and voicemail.
Here is my issue.
If you call the main number it will ring a list of extensions.
(1000,1001,1002,1003,1011)
the final destination is a ephone-dn that forwards to the auto attendant pilot of the asteriskNow system.
The call gets disconnected without reaching the asterisk system.
The debug on the CME shows the call being disconnected and the asterisk debug shows nothing.
I have changed the final destionation to the pilot of the asterisk system and get the same results.
Here is the current configs.
voice hunt-group 100 parallel
final 1015
list 1000,1001,1002,1003,1011
timeout 14
pilot 1095
dial-peer voice 8888 voip
destination-pattern 8888
session protocol sipv2
session target ipv4:10.0.0.252
dtmf-relay rtp-nte
codec g711ulaw
Futher notes:
I can dial from CME ephone to AsteriskNow extension.
I can dial from CME ephone to AsteriskNow Auto Attendant.
I can dial from AsteriskNow extension to CME ephone.
I can dial from AsteriskNow extension to the AsteriskNow Auto Attendant.
Keith
Given the following configuration, what do you think will happen when 7343 is called and no one in the hunt group answers?
ephone-dn 1 dual-line
  number 7241
  label Kathleen
  name Kathleen
  call-forward busy 5000
  call-forward noan 5000 timeout 20
  huntstop channel
ephone-dn 2 dual-line
  number 7254
  label Eleanor
  name Eleanor
  huntstop channel
ephone-dn 3 dual-line
  number 7258
  label Natasha
  name Natasha
  huntstop channel
voice hunt-group 5 parallel
  final 5000
  list 7254,7258,7241
  timeout 30
  pilot 7343
Contrary to expectations, the call  doesn't get forwarded to the hunt group final number of 5000. This is  becaue CME won't ever use the final number in a hunt group if the time  out on the hunt group is greater than the time out defined in the  ephone-dns!
  number 7241
  label Kathleen
  name Kathleen
  huntstop channel
  number 7254
  label Eleanor
  name Eleanor
  huntstop channel
  number 7258
  label Natasha
  name Natasha
  huntstop channel
  final 5000
  list 7254,7258,7241
  timeout 30
  pilot 7343
thanks for the reply.  I will make the change and let you know.
I made the timeout of the voice hunt-group 100 parallel to a time less than the call-forward time of the extensions and it made no difference.
I am still getting disconnected.
here is my config:
final 8888
timeout 10
pilot 1095
dtmf-relay rtp-nte
codec g711ulaw
number 1001
label Basement - 1001
description XXXXXXXXXX
name Basement
call-forward busy 51001
call-forward noan 51001 timeout 12
ephone-dn  4  dual-line
number 1000
label LivingRm - 1000
name LivingRm
call-forward busy 51000
call-forward noan 51000 timeout 12
ephone-dn  5  dual-line
number 1002
label Kitchen - 1002
name Kitchen
call-forward busy 51002
call-forward noan 51002 timeout 12
ephone-dn  6  dual-line
number 1003
label Laundry - 1003
name Laundry
call-forward busy 51003
call-forward noan 51003 timeout 12
ephone-dn  11  dual-line
number 1011
label keithfromoffice
name keith
call-forward busy 51011
call-forward noan 51011 timeout 12
I made the changes and i still have the issue.
Any other ideas?
