09-01-2021 04:06 PM
I am trying to tie two analog modems together using FXS ports and a trunk connection. The problem is that the modems do not provide signaling to "go off hook". Does anyone know of another way to do this? Would hoot 'n holler make any difference?
Thank you,
Chris
09-01-2021 11:09 PM
Hi Chris,
To achieve this, you would need an FXO interface on you 4300 VG Side.
FXS Interface are intended to be used with a terminal such as analogue phones or faxes
Carlo
09-02-2021 07:34 AM
So you are trying to get the modems to call each other and connect via the voip connection between the routers? That's doable.
If so, is the problem you are trying to solve that the called modem is not picking up?
Maren
09-02-2021 07:49 AM
The modems are connected to radios and when someone talks it goes through the modem and then supposed to go through the voice port on the ISR. I can get the trunk up all of the time, but since the modem does not have signaling to tell the voice port to go off hook, the voice-port doesn’t do anything.
I just need an open voice tunnel that doesn’t need any signaling. Like a leased line.
Chris
