IP Telephony and Phones
Labels
This seems like a silly problem to have. Whenever a new employee is onboarded if they are taking over a former employees extension then everyone the former employee has ever called retains that employees name as the caller ID and does not get the nam...
NewRobert by Level 1
  • 1661 Views
  • 7 replies
Hi,I have a dozen DIDs.We have 2 main lines at the reception. These 2 main lines are our old numbers we used to have since more than 15 years and now we are at a new location.So the area code of the old numbers are different from the area code of the...
Tazio4436 by Level 1
  • 1593 Views
  • 2 replies
Hello team, I try to configure rnis interface but when I use the "encapsulation ppp" command in BRI interface, I receive this message :encapsulation ppp not allowed on voice only interface some one can help me on this issue?Best regards
Isfds by Level 1
  • 397 Views
  • 0 replies
  • 5 Helpful votes
We have did numbers from XXX-9100 - XXX-9199. Just recently all incoming calls to these numbers fail to work.XXX-9110XXX-9111XXX-9112XXX-9113toXXX-9119Those ten numbers are all that don't work.  I'm not sure why or what changed that caused this to st...
rogerssa by Level 1
  • 620 Views
  • 4 replies
  • 5 Helpful votes
Hi All,We have changed phone URL for home phone service/VPN gateway and later We have uploaded the ASA certificates on to phone-VPN trust certificates. We have added new certificates to VPN gateway certificates under VPN gateway configuration but not...
Yenosh by Level 1
  • 1295 Views
  • 7 replies
Hi AllWe have a CUCM on version 11.5, we recently moved from SWSS to Flex.Am I right in saying our CUCM will still use the PLM server and will be unable to get the flex licences until we upgrade to version 12.5? Second question, on PLM I can see we h...
HiWe are looking on how to do encryption on both legs of the CUBESo between CUCM --- CUBE(inside) encryptionAnd between CUBE(outside)------ encryptionFor the inside we want to use a private CA and for the outside a public CAIs this supported? Or must...
