08-08-2012 04:43 AM - edited 03-16-2019 12:36 PM
hi,
we connecting a Quescom 300 GSM gateway to Cisco Callmanager 8.6 via SIP Trunk. We call a number and the call is established and connected. But nothing is hear end-to-end in both directions (no voice while connected). We sniffed the packets and see many RTP packets with right codec and so on.
Anybody had the same? Can somebody provide me with a configuration guide from quescom connection to cisco callmanager 8.x? Its possible that the payload type or framesize be the issue?
Thanks for any suggestions!
07-14-2013 04:49 AM
Did you get the solution for this?. If so can you share the solution . It might help me to solve this issue.
thanks in advance
regards
Ram
07-15-2013 07:26 AM
You mentioned RTP packets. What is the source and destination address? (Is it on telco side?)
Have you tried to decode RTP stream?
Check outgoing RTP packets. If they contain "normal voice" - the issue isn't on CUCM
Check incomming RTP packets. What do you hear if you decode them?
Vadym
09-07-2014 02:13 AM
I have same issue with topex mobilink ip gsm gateway.
call connected with no audio but this issue only for a outgoing calls from my extension. no issues with incoming to internal extension.
any advice plz.
09-07-2014 08:02 PM
I did connected CUBE 2921 to mobile providers by SIP trunk directly not throw gsm gateway.
I think it is better than gsm gateway
in your case if gateway connected by sip so do
clea logg
deb cssip mess
make call
sh logg
and copy paste log here
