Bookmark
Subscribe
504
Voice Quality troubleshooting with 7960 phones
mightyking
Level 6
Level 6
Hello all,
Few years ago, I found a document about how to troublshoot the voice quality using a 7960 phone into the network. I need that document now but I don't seem to be able to find it. If any of you guys know how to setup a 7960 phone to push audio sound into the network or have the document which explains how to do so, please let me know.
MK
5 Replies 5
Thanks Rob,
It was exactly the document that I was looking for but it doesn't seem that my 7961/41/71 support the tone genaration. It looks like the document is not for the phones that I have in production. Am I mistaken?
Thanks again,
MK
Hi MK,
First off you are most welcome my friend :)
I think you might be hitting this bug;
CSCee44462 Bug Details
Headline Need ability to generate inband test tone on 7941/61/70/71 like 7960
First Found-in Version 8.0(3), 5.0(1)
Status Assigned
Symptoms:
7941/61/70/71 phones cannot generate 1004Hz -15dB test tones the way a 7960 is capable of doing.
Conditions:
Any network where 7941/61/70/71 phones are being used and a test tone is needed to troubleshoot a loss plan or echo problem.
Workaround: Use the test tone on a 7940 or 7960.
Hope this helps! Sorry man.
Rob
Rob,
It looks like my 7961/41 don't have the tone generation option. I followed the document but I think it does not apply to the 7961/41. Is there any other doc for 7961/41?
Hi MK,
Sorry my friend but the Bug I referenced above (CSCee44462) still applies. This means that the Tone Generation capability does not work with 7941/7961/7971 IP Phones.
Hope this helps!
Rob
