02-04-2007 08:50 PM - last edited on 03-25-2019 07:33 PM by ciscomoderator
Fisrtly can you confirm that this translation will work and secondly is there a short cut so i can do all 4 rules in a single rule.
Cheers
Paul
02-04-2007 09:43 PM
Paul,
There are different ways of working out translation rules. If you can explain what you are trying to translate from and to, may be we can help.
Sankar.
02-05-2007 03:27 PM
Here are the translation rules i am looking to do
voice translation-rule 10000
rule 1 /^10\([0-4]..\)/ /0211114\1/
rule 2 /^12\(0..\)/ /0222224\1/
rule 3 /^12[1-3]\(..\)/ /02333322\1/
All rules are translating 5 digit numbering to PSTN numbers
rule 1 has to translate extensions 10000 -> 10499 through to 0211114000 -> 0211114499
rule 2 has to translate extensions 12000 -> 12099 through to 0222224000 -> 0222224099
rule 3 has to translate extensions 12100 -> 12399 through to 0233332200 -> 0233332499
I am pretty sure I have done rules 1 and 2 correctly. Rule 3 is the one I am concerned about. As you can see the numbers arent matching exactly. (ext 12399 -> 023333499) 1 becomes 2 and 2 beomes 3 and 3 becomes 4 in the third digit from the right.
Any help on this would be greatly appreciated.
Paul
02-05-2007 03:55 PM
Hi Paul,
you are right, rule 3 wouldn't work if written as above. Here is the rewritten config, it takes 5 rules.
rule 3 /^121\(..\)/ /02333322\1/
rule 4 /^122\(..\)/ /02333323\1/
rule 5 /^123\(..\)/ /02333324\1/
And here the output from the very helpful command "test voice translation-rule"
ccme#test voice translation-rule 10000 12100
Matched with rule 3
Original number: 12100 Translated number: 0233332200
Original number type: none Translated number type: none
Original number plan: none Translated number plan: none
ccme#test voice translation-rule 10000 12297
Matched with rule 4
Original number: 12297 Translated number: 0233332397
ccme#test voice translation-rule 10000 12399
Matched with rule 5
Original number: 12399 Translated number: 0233332499
02-05-2007 05:52 PM
Thanks for the reply
I was afraid of that answer. Is there now way to get it into one line. The translations limitation is 15 rules per translations and I am hitting that on every translation i have. I need to linit the rules somehow. I have thousands of rules to create.
Any ideas.
Cheers
Paul
02-06-2007 03:56 AM
No, if the patterns are like you shown, I don't think you can make it with less rules.
One possibility would be using IVR TCL script to manipulate the numbers, of course it requires knowledge of that programming environment.
02-06-2007 08:02 PM
Does anybody here have any ideas on the tcl script required??
Paul
02-07-2007 03:17 AM
I was thinking something else about this problem. It is true that the number of rules withing a translation-rule is limited, but the number of dial-peers can be very high.
So, if you create multiple dial-peers matching different patterns of the possible numbers, you will be able to associate different translation-rules to them, and actually have more rules in place.
02-07-2007 02:20 PM
Thanks for that. I am already implemeting over 1 hundred dial peers each matching different translation rules. It is starting to get unitdy. The customer wants to keep 5 digit numbering plan and has hundreds of branches.
I am still looking or a more practical way forward if there is one.
But thanks again for all your suggestions.
Paul
