09-19-2012 11:43 PM - edited 03-16-2019 01:18 PM
We have created a Voicemail pilot number 1000. We have a UCCE solution where by customer input an agent extension, if the agent is available the call is routed to him. If the agent is not available, the ICM checks for other agent availability, if none are available the call should be routed to the intial extension which the customer input.
say if the agent extension is 1234. We have configured ICM to send 1000#1234 to be sent to callmanager. This flow will be ICM--->CVP---->CUSP---->CUCM.
My understanding is if i dial 1000#1234, the voicemail box of 1234 is directky accessed. But callmanager logs show the call is rejected. Any ideas on how to proceed
Solved! Go to Solution.
09-20-2012 06:53 AM
How do you figure that? this will not work unless you build it that way. You will need to do the following:
HTH,
Chris
09-20-2012 06:53 AM
HTH,
Chris
