Voicemail database corrupted! HELP PLEASE!
cgallego1
10 Replies 10
Nadeem Ahmed
Please follow the factory re-install and instruction given in this link, also is it fresh one do you have any backup ?
http://www.acumenitsupport.com/phone-systems/uc500-uc520-uc540-uc560-voicemail-cue-non-functional-and-inaccessible-service-module-is-trying-to-recover-from-resetshutdown-error-failed
Br, Nadeem Please rate all useful post.
It's giving me two options. Is a factory re-install necessary?
If your using as a fresh install then you can perform the factory re-install.
Br,
Nadeem
Thank you for the quick replies. I am extremely inexperienced with CCA/Cisco. Are these commands through the link supposed to be entered into CUE Exec commands window?
those needs to be run from CLI you need to console to CUE
login to CME/GW
service-module <ism0/0> session
Br,
nadeem
Actually after it seemed like everything was up and running, the same problem is now re-occurring. I went through the #2 step in the image above and it was working after this. Now when users hit the mailbox button, it is still doing the same thing. I will follow up.
In the end, the problem was with our 48 port switch not properly connecting to our UC. Once updating the software package on the UC as well as the firmware on our 48 port Cisco switch occurred, everything came back up and running. Only small configurations had to be made after this such as auto attendant options...
Thanks for all previous help.
yes
I've tried every step on this link and successfully did a factory reset. Still same problem. I don't know what the issue is. Everything seems to be up and running but its not. Please see below if you have a chance. Thanks for all the help so far...
