Beginner
Voicemail database corrupted! HELP PLEASE!
10 REPLIES 10
Please follow the factory re
Please follow the factory re-install and instruction given in this link, also is it fresh one do you have any backup ?
http://www.acumenitsupport.com/phone-systems/uc500-uc520-uc540-uc560-voicemail-cue-non-functional-and-inaccessible-service-module-is-trying-to-recover-from-resetshutdown-error-failed
Br, Nadeem Please rate all useful post.
Beginner
It's giving me two options.
It's giving me two options. Is a factory re-install necessary?
If your using as a fresh
If your using as a fresh install then you can perform the factory re-install.
Br,
Nadeem
Beginner
Thank you for the quick
Thank you for the quick replies. I am extremely inexperienced with CCA/Cisco. Are these commands through the link supposed to be entered into CUE Exec commands window?
those needs to be run from
those needs to be run from CLI you need to console to CUE
login to CME/GW
service-module <ism0/0> session
Br,
nadeem
Beginner
Highlighted
Beginner
Actually after it seemed like
Actually after it seemed like everything was up and running, the same problem is now re-occurring. I went through the #2 step in the image above and it was working after this. Now when users hit the mailbox button, it is still doing the same thing. I will follow up.
Beginner
In the end, the problem was
In the end, the problem was with our 48 port switch not properly connecting to our UC. Once updating the software package on the UC as well as the firmware on our 48 port Cisco switch occurred, everything came back up and running. Only small configurations had to be made after this such as auto attendant options...
Thanks for all previous help.
Beginner
Cisco Configuration Assistant
yes
Beginner
I've tried every step on this
I've tried every step on this link and successfully did a factory reset. Still same problem. I don't know what the issue is. Everything seems to be up and running but its not. Please see below if you have a chance. Thanks for all the help so far...
Content for Community-Ad
August's Community Spotlight Awards
