06-26-2013 01:02 AM - edited 03-16-2019 06:05 PM
Question:
My voicemail setup is not working when i dial an extention it is not forwarding to the mailbox nuber instead i get a message that the extension is busy. Did some debugging and saw a "being refused message"
Configuration:
UC router
ephone-dn 15
number 223
label XXX
description 223-XXX
name XXX
call-forward busy 901
call-forward noan 901 timeout 5
ephone-dn 100
number 5...
description DN to transfer directly to VM
call-forward all 901
telephony-service
voicemail 901
dial-peer voice 901 voip
destination-pattern 901
session protocol sipv2
session target ipv4:192.168.1.2
dtmf-relay sip-notify
codec g711ulaw
no vad
CUE
CUE# show user detail username waseem
Username: XXX
Full Name: XXX
First Name: XXX
Last Name: XXX
Nickname: XXX
Phone: 223
Phone(E.164): 5223
Fax:
Email:
Epage:
Language: systemDefault
GroupMember: <none>
GroupOwner: <none>
Privileges: <none>
CUE# show voicemail mailboxes
OWNER MSGS NEW SAVE DEL BCST FUTR FAX MSGTIME MBXSIZE USED
"XXX" 0 0 0 0 0 0 0 0 300 0 %
DEbug result:
.Jun 26 07:48:43.074: %CALL_CONTROL-6-CALL_LOOP: The incoming call has a global identifier already present in the list of currently handled calls. It is being refused.
.Jun 26 07:48:43.110: //3645//TCL :/tcl_PutsObjCmd: IP IVR Disconnect Status = RESULT=di_017
.Jun 26 07:48:43.114: //3645//TCL :/tcl_PutsObjCmd:
Call failed. Play prompt and collect digit
Followed the steps on this link:
Thanks in advance
Solved! Go to Solution.
06-30-2013 02:06 AM
Hi Paolo,
Is it possible for me to install the same CUE 8.6.6 version? What would be the effect if i did an install/upgrade on the ISM module? User calls?
Thanks.
06-30-2013 03:15 AM
8.6.6 is the latest. Maybe something got corrupted.
06-30-2013 03:18 AM
Hi Paolo,
can i install the same version? If i make the module offline what effect could that be on the user calls? My AA is runnning via TCL script.. Thanks
06-30-2013 03:31 AM
You can install any version you want. While installing, CUE will not work.
06-30-2013 03:35 AM
Sorry im kinda lost... CUE will not work meaning? all phones cannot place and recieve calls? Or CUE functions like VM will not work?.. sorry for the question..
06-30-2013 04:38 AM
We are talking CUE not CME.
If you are not sure, do the works at night.
06-30-2013 11:08 PM
Hi Paolo,
Yes CUE...now i know the difference...CUE = VM, IVR... CME is the telephony services... Now on the process of installing the CUE in the ISM module.. Found this nice link to guide me..
http://www.cisco.com/en/US/docs/voice_ip_comm/unity_exp/rel8_6/install/installsre.html#wp1129275
07-03-2013 03:15 AM
Hi Paolo,
sorry for coming back late...I have read a lot of stuff regarding issues with CUE upgrade and install.. in my case i have an RMA of the module with me now. I noticed as well that (see image) when i issued a reset of the module in the terminal monitor nothign is shown that the module restarted but instead i see the continous "RBIP Registration REquest" so the module is busted? I will be going to the site hopefully in the coming weeks/days to replace the module with the new one. Yes i was doing the upgrade remotely via VPN . what do you think of the busted module? Im using thie ISM-SRE-300-K9 module
07-03-2013 04:29 AM
The module seems fine, you should use installer image, as described in documentation.
07-03-2013 04:34 AM
installer image? =
cue-installer.SPA.sme.8.6.6 = this one?
i have tried it with the boot helper mothed but after the install the module goes into loop. Im suspecting as well since i am doing the installation via VPN the file transfer might get corrupted.
i tried also using the service-module ism 0/0 install url ftp://x.x.x.x/cue-vm-k9.SPA.sme.8.6.6.pkg same result module will go into loop after the language selection..
07-03-2013 06:14 AM
VPN should not cause corruption.
Try placing all files and tools on a PC local to the CUE and remote into into.
