06-14-2013 12:56 PM - edited 03-16-2019 05:53 PM
Hi All,
I am facing issue with voicemail ports. Few voicemail ports are showing status as Unregistered where some voicemail ports are registerd. When checked in RTMT Status Reason shows message "DirectoryNumberMismatch".
What can be the issue ?
I am using Unity Connection 7.x and CUCM 7.x.
Thanks !
06-14-2013 01:07 PM
Hi Amalraj,
Sorry man!! Horrible info...my bad!
Cheers!
Rob
"go easy...step lightly...stay free "
- The Clash
06-14-2013 01:27 PM
Hi Rob,
Thanks for the reply.
But how to check DN 1204 in unity connection. There is no such information regarding DN.
Thanks !
06-14-2013 11:23 PM
Hi Amalraj,
Can u cross-check for the numbers in Route Plan report in Call manager?
May be some DNs are conflicting.
regds,
aman
