VoiIP Codec and config
zain_gabon
Hi Support,
i read that for configuring VoIP, you must considere codec points, the code G.711 and G.729A.
I want to know regarding configuring routers or swicthes, how can i chose one or other codec?
How can i decide to use G.711 or another codec?
6 Accepted Solutions
Jaime Valencia
The configuration depends on the call control agent you'll be using.
Most usually you choose the codec based on the BW you have or the MOS you need.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Payal Bhaduri
Each codec provides a certain quality of speech. The quality of transmitted speech is a subjective response of the listener. A common benchmark used to determine the quality of sound produced by specific codecs is the mean opinion score (MOS). With MOS, a wide range of listeners judge the quality of a voice sample (corresponds to a particular codec) on a scale of 1 (bad) to 5 (excellent). The scores are averaged to provide the MOS for that sample. This table shows the relationship between codecs and MOS scores.
Compression Method
Bit Rate (kbps)
MOS Score
Compression Delay (ms)
G.711 PCM
64
4.1
0.75
G.726 ADPCM
32
3.85
G.728 LD-CELP
16
3.61
3 to 5
G.729 CS-ACELP
8
3.92
G.729 x 2 Encodings
8
3.27
G.729 x 3 Encodings
8
2.68
G.729a CS-ACELP
8
3.7
G.723.1 MP-MLQ
6.3
3.9
30
G.723.1 ACELP
5.3
3.65
30
This document will help you understand about codecs
http://www.cisco.com/en/US/tech/tk1077/technologies_tech_note09186a00800b6710.shtml
Depends on the Bandwidth
Inter-site -- G729
Intra-site - G711/G722
There's a slight difference between G711 and G729 audio quality..but a user wouldn't notice this in the course of a conversation.
PS: Rate useful posts.!
Assuming you're using H323 in the VOIP dial peer config mode just type codec ? and you'll get the list of options.
java
java
IP Phone A----- R1 ------ R2 --- IP Phone B
A(1000) calls B(2000)
R1  - Outgoing Dial-peer
dial-peer voice 2000 voip
destination-pattern 2...
session-target ipv4:
codec g729
R2 - incoming Dial-peer
dial-peer voice 9999 voip
incoming-called number 2...
codec g729
now the call hits Phone B as a G729 call :-)
If you are using CUCM use "regions"
This post helps you to understand dial-peer matching...
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_tech_note09186a008010fed1.shtml
PS: Rate useful posts..
8 Replies 8
Jaime Valencia
java
java
Payal Bhaduri
Compression Method
Bit Rate (kbps)
MOS Score
G.711 PCM
64
4.1
0.75
G.726 ADPCM
32
3.85
G.728 LD-CELP
16
3.61
3 to 5
G.729 CS-ACELP
8
3.92
G.729 x 2 Encodings
8
3.27
G.729 x 3 Encodings
8
2.68
G.729a CS-ACELP
8
3.7
G.723.1 MP-MLQ
6.3
3.9
30
G.723.1 ACELP
5.3
3.65
30
Inter-site -- G729
Thanks for your quick response
but can you please provide me with an example
if i have a wan link 512 kb/s, how can i choose code?
do you have router commande to choose codec?
regars
java
java
codec g729
codec g729
Thanks for your quick supports
