VoIP issues after IOS upgrade
Kaushik Ray
Hello I am seeing a strange issue;
There is a Hub Router with IOS version c2800nm-spservicesk9-mz.124-24.T3.bin
There are some remote sites that connects to this Hub Router and all the remote sites run CMEs.
All the IP Phones on them are 7942s.
All services were working fine.
I had a requirement to upgrade the IOS (as the Hub Router needs to run VPN) and I got hold of a new flash put in all the relevant files that exists on the old flash apart from the new IOS image which I put in as c2800nm-adventerprisek9-mz.150-1.M9.bin
Powered down the router
Swapped out the flash cards and powered up the router again.
Data traffic was working fine
But the IP phones on the remote sites started having problems. When I called out the numbers I could see them hitting the router but could not hear the other end.
Since they are CMEs I thought the onshore router IOS change would not have affected anything.
I reverted back to the old IOS and all services have been restored and Voice services back to normal.
I compared all the files between the old flash and new flash (which I have attached with this post) and all identical including the file size of each file
apart from the following (these files exist on the old one twice but once on the new flash)
78     2496963 Feb 27 2008 19:53:18 apps11.8-3-2-27.sbn
79     7821474 Jan 04 2008 11:36:00 apps37sccp.1-1-1-1.bin
80     2494499 Feb 27 2008 20:03:44 apps41.8-3-2-27.sbn
and the following file exists on the old one but not on the new one
81        9968 Dec 17 2008 22:52:00 xml-test.html
But I would not have thought that these would have caused issues all the phones are 7942 and both the old and the new flash cards have
82      531737 Jun 02 2010 12:58:44 cnu42.9-0-3TH1-22.sbn
83     2162646 Jun 02 2010 12:59:10 cvm42sccp.9-0-3TH1-22.sbn
84      343211 Jun 02 2010 12:58:58 dsp42.9-0-3TH1-22.sbn
85     1756858 Jun 02 2010 12:59:04 jar42sccp.9-0-3TH1-22.sbn
86         676 Jun 02 2010 12:58:26 SCCP42.9-0-3S.loads
87         680 Jun 02 2010 12:58:32 term42.default.loads
88         680 Jun 02 2010 12:58:38 term62.default.loads
89     4581763 Jun 02 2010 12:58:50 apps42.9-0-3TH1-22.sbn
Any advice on this will be much appreciated if I am missing something.
Look forward to your advice and guidance and many thanks in advance.
Hi Ray,
I think u need to stick to same 12.4  version since 15.0(1)M9 is required for ISR G2 platforms.you can check the sheet.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/requirements/guide/33matrix.htm
In your case , it is 15.0(1)M9 installed on ISR 2800 router.
upgrading to above version 15.0(1)M9  also requires upgradation to CME 8.
This is what I think.
regds,
aman
18 Replies 18
How the remote CMEs are connected through which call control protocol? SIP or H.323
Are you added "trusted address" which is new in 15.x image
Thanks a lot for your reply
the remote CMEs are all configured as H323
h323-gateway voip bind srcaddr xxx.xxx.xxx.xxx
and where do i need to add "trusted address" command?
Also I am running CME version as this
sh telephony-service
CONFIG (Version=7.1)
Version 7.1
Cisco Unified Communications Manager Express
For on-line documentation please see:
and Cisco site says this should be compatible with the IOS version I am running (
c2800nm-adventerprisek9-mz.150-1.M9.bin)
15.0(1)M9
7.1
7.1.1.0
Hi Kaushik,
trusted list commands are available under
voice service voip
you can use following for testing and then later add the trusted IP addresses. Following will disable trust list feature.
voice service voip
no ip address trusted authenticate
“If you have knowledge, let others light their candles in it.”
HI Amansin74
thanks for your reply. but the current version on the router i am trying to put in is before the version where this command was allowed?
My current version
CME verision 7.1
Cisco advices this was enabled from the following
15.1(2)T
Cisco Unified CME 8.1
This command was introduced.
voice service voip
ip address trusted authenicate
ip address trusted list
ipv4 192.168.0.1 255.255.255.0
or
ipv4 0.0.0.0 0.0.0.0  (for all the IP addresses)
#show ip trusted address list
try the above command
Thanks again
Is this to be put in the Hub Router and the trusted list to be all the remote h323 ipaddresses?
Also this command i found int the Cisco site says
15.1(2)T
But my Router version will be
c2800nm-adventerprisek9-mz.150-1.M9.bin and CME version 7.1 or do I need for any IOS version 15 and upwards?
thanks
It does not allow the command under voice service voip as shown below:
Router#sh version | include flas
System image file is "flash:c2800nm-adventerprisek9-mz.150-1.M9.bin"
Router#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
Router(config)#voice service voi
Router(config)#voice service voip
Router(conf-voi-serv)#no ip add ?
% Unrecognized command
Router(conf-voi-serv)#ip add?
Hi Ray,
Toll Fraud Prevention was introduced from IOS 15.1(2)T
in your case , IOS has version 15.0(1)M9
regds,
aman
Thanks Aman
Hence my original question; if you could please see my original post I started having issues on VoIP by upgrading to
15.0(1)M9 and when I reverted back to the 12 IOS VoIP was restored.
I am not sure why this would happen; Any ideas.
If you can kindly check my original post; i have also attached the old and new flash card contents output.
Thanks again
Hi Ray,
regds,
aman
Thanks a lot Aman I will give it a try; I was actually confused as the compatibility matrix still showed
15.0(1)M9
7.1
7.1.1.0
But i will try with the 12.4 version
thanks again
Hi Ray,
Jus a correction , it is 15.0(1)M and not 15.0(1)M9 . 9 refers to note.
But what I referred is correct .
regds,
aman
Thanks Aman
Upgraded the Router to
c2811nm-adventerprisek9-mz.124-24.T3.bin from the SP services Variant and voice using CME is working fine.
As you pointed out the 15 version may need an upgrade on the CME as well.
Thanks a lot again!
