VoIP issues after IOS upgrade
Kaushik Ray
Hello I am seeing a strange issue;
There is a Hub Router with IOS version c2800nm-spservicesk9-mz.124-24.T3.bin
There are some remote sites that connects to this Hub Router and all the remote sites run CMEs.
All the IP Phones on them are 7942s.
All services were working fine.
I had a requirement to upgrade the IOS (as the Hub Router needs to run VPN) and I got hold of a new flash put in all the relevant files that exists on the old flash apart from the new IOS image which I put in as c2800nm-adventerprisek9-mz.150-1.M9.bin
Powered down the router
Swapped out the flash cards and powered up the router again.
Data traffic was working fine
But the IP phones on the remote sites started having problems. When I called out the numbers I could see them hitting the router but could not hear the other end.
Since they are CMEs I thought the onshore router IOS change would not have affected anything.
I reverted back to the old IOS and all services have been restored and Voice services back to normal.
I compared all the files between the old flash and new flash (which I have attached with this post) and all identical including the file size of each file
apart from the following (these files exist on the old one twice but once on the new flash)
78     2496963 Feb 27 2008 19:53:18 apps11.8-3-2-27.sbn
79     7821474 Jan 04 2008 11:36:00 apps37sccp.1-1-1-1.bin
80     2494499 Feb 27 2008 20:03:44 apps41.8-3-2-27.sbn
and the following file exists on the old one but not on the new one
81        9968 Dec 17 2008 22:52:00 xml-test.html
But I would not have thought that these would have caused issues all the phones are 7942 and both the old and the new flash cards have
82      531737 Jun 02 2010 12:58:44 cnu42.9-0-3TH1-22.sbn
83     2162646 Jun 02 2010 12:59:10 cvm42sccp.9-0-3TH1-22.sbn
84      343211 Jun 02 2010 12:58:58 dsp42.9-0-3TH1-22.sbn
85     1756858 Jun 02 2010 12:59:04 jar42sccp.9-0-3TH1-22.sbn
86         676 Jun 02 2010 12:58:26 SCCP42.9-0-3S.loads
87         680 Jun 02 2010 12:58:32 term42.default.loads
88         680 Jun 02 2010 12:58:38 term62.default.loads
89     4581763 Jun 02 2010 12:58:50 apps42.9-0-3TH1-22.sbn
Any advice on this will be much appreciated if I am missing something.
Look forward to your advice and guidance and many thanks in advance.
18 Replies 18
hi Ray,
thanks for update.
can u share the show version /show flash from working router?
regds,
aman
Aman
sh flash:
-#- --length-- -----date/time------ path
1     59478200 Nov 25 2013 10:53:14 c2811nm-adventerprisek9-mz.124-24.T3.bin
2       527849 Jun 26 2010 03:46:46 128MB.sdf
3      2496963 Feb 27 2008 19:53:18 apps11.8-3-2-27.sbn
4      7821474 Jan 04 2008 11:36:00 apps37sccp.1-1-1-1.bin
5      2494499 Feb 27 2008 20:03:44 apps41.8-3-2-27.sbn
6         9968 Dec 17 2008 22:52:00 xml-test.html
7         3412 Dec 17 2008 22:52:00 xml.template
8        16080 Aug 20 2004 05:58:00 Vibe.raw
9          870 Dec 17 2008 22:51:58 UPARROW.GIF
10         642 Feb 27 2008 20:04:32 term61.default.loads
11         642 Feb 27 2008 20:04:32 term41.default.loads
12         662 Feb 27 2008 19:54:04 term11.default.loads
13         662 Feb 27 2008 19:54:04 term06.default.loads
14        2431 Dec 17 2008 22:53:44 telephony_service.html
15         174 Dec 17 2008 22:51:58 Tab.gif
16         843 Dec 17 2008 22:51:58 SXICONAD.GIF
17         638 Feb 27 2008 20:04:30 SCCP41.8-3-3S.loads
18         658 Feb 27 2008 19:54:02 SCCP11.8-3-3S.loads
19       14160 Aug 20 2004 05:58:00 Sax2.raw
20       10800 Aug 20 2004 05:58:00 Sax1.raw
21       49986 Apr 23 2007 09:56:00 S00105000300.sbn
22         495 Mar 16 2006 23:27:34 RingList.xml
23        4000 Aug 20 2004 05:58:00 Ring7.raw
24        4000 Aug 20 2004 05:58:00 Ring6.raw
25        4000 Aug 20 2004 05:58:00 Ring5.raw
26        4000 Aug 20 2004 05:58:00 Ring4.raw
27        4000 Aug 20 2004 05:58:00 Ring3.raw
28        4000 Aug 20 2004 05:58:00 Ring2.raw
29        4000 Aug 20 2004 05:58:00 Ring1.raw
30        7200 Aug 20 2004 05:58:00 Pulse1.raw
31        9360 Aug 20 2004 05:58:00 Pop.raw
32        1347 Dec 17 2008 22:51:58 Plus.gif
33       15360 Aug 20 2004 05:58:00 Piano2.raw
34        8160 Aug 20 2004 05:58:00 Piano1.raw
35     2029545 Aug 29 2006 10:33:00 P00503021500.bin
36      350198 May 04 2005 14:08:00 P00405000700.sbn
37      349794 May 04 2005 14:08:00 P00405000700.bin
38      130228 Feb 27 2008 20:01:58 P00308000500.sbn
39      705536 Feb 27 2008 20:01:54 P00308000500.sb2
40         458 Feb 27 2008 20:01:36 P00308000500.loads
41      129824 Feb 27 2008 20:01:36 P00308000500.bin
42       78428 Dec 17 2008 22:51:58 normal_user.js
43        3866 Dec 17 2008 22:51:58 normal_user.html
44      496521 Mar 29 2004 11:40:00 music-on-hold.au
45       12720 Aug 20 2004 05:58:00 MusicBox.raw
46        4558 Dec 17 2008 22:51:58 LOGOHOME.GIF
47       16080 Aug 20 2004 05:58:00 KotoEffect.raw
48      315827 Feb 27 2008 20:04:30 jar41sccp.8-3-2-27.sbn
49      307192 Feb 27 2008 19:54:02 jar11sccp.8-3-2-27.sbn
50        8160 Aug 20 2004 05:58:00 Jamaica.raw
51       16080 Aug 20 2004 05:58:00 HarpSynth.raw
52       15840 Aug 20 2004 05:58:00 FilmScore.raw
53        6146 Dec 17 2008 22:51:58 ephone_admin.html
54      530601 Feb 27 2008 20:04:26 dsp41.8-3-2-27.sbn
55      326315 Feb 27 2008 19:53:58 dsp11.8-3-2-27.sbn
56       13440 Aug 20 2004 05:58:00 Drums2.raw
57        9600 Aug 20 2004 05:58:00 Drums1.raw
58         864 Dec 17 2008 22:51:58 downarrow.gif
59       16344 Dec 17 2008 22:51:58 DOM.JS
60        2823 Jul 02 2007 21:30:58 DistinctiveRingList.xml
61         953 Dec 17 2008 22:51:56 Delete.gif
62     2452629 Feb 27 2008 20:04:20 cvm41sccp.8-3-2-27.sbn
63     2387207 Feb 27 2008 19:53:54 cvm11sccp.8-3-2-27.sbn
64      341023 Apr 09 2007 16:02:00 CP7912080003SCCP070409A.sbin
66      547146 Feb 27 2008 20:03:52 cnu41.8-3-2-27.sbn
67      551014 Feb 27 2008 19:53:26 cnu11.8-3-2-27.sbn
68         490 Apr 14 2009 03:47:54 CME-locale-en_GB-English-7.0.1.1.tar.cfg
69       10800 Aug 20 2004 05:58:00 ClockShop.raw
70       16080 Aug 20 2004 05:58:00 Classic2.raw
71        8160 Aug 20 2004 05:58:00 Classic1.raw
72        1029 Dec 17 2008 22:51:56 CiscoLogo.gif
73       16040 Aug 20 2004 05:58:00 Chime.raw
74       12240 Aug 20 2004 05:58:00 CallBack.raw
75        8160 Aug 20 2004 05:58:00 Bass.raw
76        5040 Aug 20 2004 05:58:00 AreYouThereF.raw
77        5280 Aug 20 2004 05:58:00 AreYouThere.raw
78        3987 Dec 17 2008 22:51:56 admin_user.html
79      679306 Dec 19 2008 01:53:08 admin_user.js
80        8160 Aug 20 2004 05:58:00 Analog1.raw
81        8160 Aug 20 2004 05:58:00 Analog2.raw
32927744 bytes available (95809536 bytes used)
Hi Ray,
Were you able to resolve the issue ?
one thing you want to check is the h323-gateway voip bind srcaddr xxx.xxx.xxx.xxx. Try using the loopback interface for
Hope that helps !!
Danny
Danny Thanks for your reply.
the h323 binding is still in place after the IOS upgrade but had to revert back to the older IOS to restore VoIP services.
No have downloaded the c2811nm-adventerprisek9-mz.124-24.T3 image and waiting for a downtime to upload it into the flash and try once more.
will advice the outcome as soon as i have some
