Hello everyone,
At our company we have a redundant ISP connection to two separate ISP's.
We are also using VoIP on the network.
Currently one ISP connection is used primarily and the second on is just used as a backup.
I was wondering if it is possible to use the first connection primarily for data traffic and the second connection for VoIP traffic?
We use different VLAN's for voice and data.
Kind regards
Dwayne
Solved! Go to Solution.
Sure, it all comes down to IP traffic routing, there is few ways of achieving it, i.e. policy based routing, etc. I would recommend asking your question on the Network Infrastructure - WAN forum.
HTH, please rate all useful posts!
Chris
Chris
Hi Chris,
Thank you very much for your reply.
You have pointed me in the right direction!.
