VPDM in NIM module
bkhanal1971
Level 3
Level 3
I have a 4331 router with PVDM4-128. I will be using this router for CME. I also have a NIM module with 1 port T1/E1. I will be terminating E1 PRI circuit in this card.
After reading this link
http://www.cisco.com/c/en/us/support/docs/routers/4000-series-integrated-services-routers/118792-config-isr-00.html
, I have the impression that I also need to have the PVDM installed in the NIM module in order to configure this port for voice circuit termination. Can somebody confirm whether the PVDM in the card is the must?
Thanks, Khanal
16 Replies 16
Hello Nipun,
But I am getting a signal from E1 when I put debug isdn q921 and q931 but the incoming and outgoing calls won't work
Is this the only way for it to work? because I never faced something like this
Add an output for "show controller e1" and "show isdn status" please.
