VWIC3-1MFT-T1/E1
Leonardo Santana
I installed an VWIC3-1MFT-T1/E1 but when i try to configure this module the router says that not exists
#controller e1 0/0/3
% Invalid input detected at '^' marker.
follow the sh diag
i have an 2951 with two PVDM-3 64
Slot 0/0: VWIC3-2MFT-T1/E1(E1)
Slot 0/1: VIC3-2FXS/DID
Slot 0/2: VIC2-4FXO(FXO)
Slot 0/3: VWIC3-1MFT-T1/E1(E1)
sh diag
Slot 0:
        C2951 Mother board 3GE, integrated VPN and 4W Port adapter, 12 ports
        Port adapter is analyzed
        Port adapter insertion time 00:39:18 ago
        EEPROM contents at hardware discovery:
        PCB Serial Number        : FOC15224SHD
        Hardware Revision        : 1.1
        Part Number              : 73-11836-06
        Top Assy. Part Number    : 800-30793-03
        Board Revision           : D0
        Deviation Number         : 0
        Fab Version              : 03
        Product (FRU) Number     : CISCO2951/K9
        Version Identifier       : V03
        CLEI Code                : CMMBM00ARA
        Processor type           : C8
        Chassis Serial Number    : FTX1529AK6T
        Chassis MAC Address      : 30e4.db10.c9e0
        MAC Address block size   : 96
        Manufacturing Test Data  : 00 00 00 00 00 00 00 00
        EEPROM format version 4
        EEPROM contents (hex):
          0x00: 04 FF C1 8B 46 4F 43 31 35 32 32 34 53 48 44 40
          0x10: 06 15 41 01 01 82 49 2E 3C 06 C0 46 03 20 00 78
          0x20: 49 03 42 44 30 88 00 00 00 00 02 03 CB 8C 43 49
          0x30: 53 43 4F 32 39 35 31 2F 4B 39 89 56 30 33 20 D9
          0x40: 04 40 C1 CB C2 C6 8A 43 4D 4D 42 4D 30 30 41 52
          0x50: 41 09 C8 C2 8B 46 54 58 31 35 32 39 41 4B 36 54
          0x60: C3 06 30 E4 DB 10 C9 E0 43 00 60 C4 08 00 00 00
          0x70: 00 00 00 00 00 F3 00 03 40 01 63 FF FF FF FF FF
          0x80: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x90: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0xA0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0xB0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0xC0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0xD0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0xE0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0xF0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
        Internal Power Supply information
        Top Assy. Part Number    : 341-0226-02
        PCB Serial Number        : DCA1524K2NM
        RMA Test History         : 00
        RMA Number               : 0-0-0-0
        RMA History              : 00
        Version Identifier       : V02
        Product (FRU) Number     : PWR-2921-51-AC
        CLEI Code                : 0000000000
        Board Revision           : A0
          0x00: 04 FF 40 05 E2 DF 45 01 55 00 E2 02 88 00 00 00
          0x10: 00 C1 8B 44 43 41 31 35 32 34 4B 32 4E 4D 03 00
          0x20: 81 00 00 00 00 04 00 89 56 30 32 20 CB 8E 50 57
          0x30: 52 2D 32 39 32 31 2D 35 31 2D 41 43 C6 8A 30 30
          0x40: 30 30 30 30 30 30 30 30 F3 00 59 41 01 22 42 00
          0x50: 05 F8 00 50 01 F3 18 3B 02 F0 19 D9 03 E8 1B 76
          0x60: 04 E2 1C 49 05 D9 1D 1B 06 D8 1D ED 07 CF 1E BF
          0x70: 08 CE 1F 40 09 C2 1F B8 0A B8 20 34 0B B7 20 B0
          0x80: 0D AF 21 0C 0F 9F 21 67 11 91 21 94 13 87 21 C0
          0x90: 17 6E 21 DB 1B 57 21 EA 1F 3F 21 E2 23 28 21 D4
          0xA0: 27 0A 21 CD 42 41 30 FF FF FF FF FF FF FF FF FF
        PVDM Slot 0:
        64-channel (G.711) Voice/Fax PVDM3 DSP DIMM PVDM daughter card
        Hardware Revision        : 1.0
        Part Number              : 73-11809-03
        Board Revision           : B0
        Fab Version              : 03
        PCB Serial Number        : FOC15255956
        RMA History              : 00
        Processor type           : 00
        Product (FRU) Number     : PVDM3-64
        Version Identifier       : V01
          0x00: 04 FF 40 05 DB 41 01 00 82 49 2E 21 03 42 42 30
          0x10: 88 00 00 00 00 02 03 C1 8B 46 4F 43 31 35 32 35
          0x20: 35 39 35 36 03 00 81 00 00 00 00 04 00 09 00 CB
          0x30: 8F 50 56 44 4D 33 2D 36 34 20 20 20 20 20 20 20
          0x40: 89 56 30 31 20 D9 02 40 C1 FF FF FF FF FF FF FF
          0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
        PVDM Slot 1:
        Board Revision           : B0
        Fab Version              : 03
        PCB Serial Number        : FOC15232DHE
        RMA History              : 00
        Processor type           : 00
          0x10: 88 00 00 00 00 02 03 C1 8B 46 4F 43 31 35 32 33
          0x20: 32 44 48 45 03 00 81 00 00 00 00 04 00 09 00 CB
        WIC Slot 0:
        VWIC2-2MFT-T1/E1 - 2-Port RJ-48 Multiflex Trunk - T1/E1
        Hardware Revision        : 0.0
        Top Assy. Part Number    : 800-22629-05
        Board Revision           : B0
        Fab Version              : 04
        PCB Serial Number        : FOC11521VTL
        RMA History              : 00
        Product (FRU) Number     : VWIC2-2MFT-T1/E1
          0x00: 04 FF 40 03 FC 41 00 00 C0 46 03 20 00 58 65 05
          0x10: 42 42 30 88 00 00 00 00 02 04 C1 8B 46 4F 43 31
          0x20: 31 35 32 31 56 54 4C 03 00 81 00 00 00 00 04 00
          0x30: CB 90 56 57 49 43 32 2D 32 4D 46 54 2D 54 31 2F
          0x40: 45 31 89 56 30 31 20 D9 02 40 C1 FF FF FF FF FF
        WIC Slot 1:
        3rd generation - FXS DID Voice daughter card (2 port)
        Top Assy. Part Number    : 800-33587-01
        Board Revision           : D0
        Fab Version              : 08
        PCB Serial Number        : FOC15326E7Z
        RMA History              : 00
        Product (FRU) Number     : VIC3-2FXS/DID
        CLEI Code                : IP9IAB3CAC
        Longitudinal Calibration : 01 10 10 95 69 10 10 9E
                                   7A
          0x00: 04 FF 40 06 21 41 01 00 C0 46 03 20 00 83 33 01
          0x10: 42 44 30 88 00 00 00 00 02 08 C1 8B 46 4F 43 31
          0x20: 35 33 32 36 45 37 5A 03 00 81 00 00 00 00 04 00
          0x30: CB 8D 56 49 43 33 2D 32 46 58 53 2F 44 49 44 89
          0x40: 56 30 33 20 D9 02 40 C1 C6 8A 49 50 39 49 41 42
          0x50: 33 43 41 43 D3 09 01 10 10 95 69 10 10 9E 7A FF
        WIC Slot 2:
        2nd generation - FXO Voice daughter card (4 port)
        Hardware Revision        : 5.0
        Top Assy. Part Number    : 800-21589-04
        Board Revision           : A0
        Deviation Number         : 0-0
        Fab Version              : 04
        PCB Serial Number        : FOC11471LKY
        RMA History              : 00
        Product (FRU) Number     : VIC2-4FXO
        CLEI Code                : CNUIAXJAAB
          0x00: 04 FF 40 00 4C 41 05 00 C0 46 03 20 00 54 55 04
          0x10: 42 41 30 80 00 00 00 00 02 04 C1 8B 46 4F 43 31
          0x20: 31 34 37 31 4C 4B 59 03 00 81 00 00 00 00 04 00
          0x30: CB 89 56 49 43 32 2D 34 46 58 4F 89 56 30 33 20
          0x40: C6 8A 43 4E 55 49 41 58 4A 41 41 42 FF FF FF FF
        WIC Slot 3:
        VWIC3-1MFT-T1/E1 - 1-Port RJ-48 Multiflex Trunk - T1/E1
        Top Assy. Part Number    : 800-34657-01
        Part Number              : 73-13419-01
        Board Revision           : A0
        Fab Version              : 05
        PCB Serial Number        : FOC15426JHA
        Product (FRU) Number     : VWIC3-1MFT-T1/E1
        CLEI Code                : COUIA7PCAA
        RMA History              : 00
          0x00: 04 FF 40 06 ED 41 01 00 C0 46 03 20 00 87 61 01
          0x10: 82 49 34 6B 01 42 41 30 88 00 00 00 00 02 05 C1
          0x20: 8B 46 4F 43 31 35 34 32 36 4A 48 41 89 56 30 31
          0x30: 20 CB 90 56 57 49 43 33 2D 31 4D 46 54 2D 54 31
          0x40: 2F 45 31 C6 8A 43 4F 55 49 41 37 50 43 41 41 03
          0x50: 00 81 00 00 00 00 04 00 D9 03 40 C1 CB FF FF FF
Embedded Service Engine 0/0 :
  Total platform memory : 524288K bytes
  Total 2nd core memory : 0K bytes
  Start of physical address for 2nd core : 0x20000000
  Number of blocks of memory for 2nd core : 1
  2nd core configured disabled
  L2 cache ways for 2nd core : 0
On the DSP Calc says that i need more PVDM so the module will not work?
Leonardo Santana
Leonardo Santana
*** Rate All Helpful Responses***
paolo bevilacqua
Often asked, had you searched before.
Configure 'card type'.
paolo bevilacqua
I forgot the card type!
And we do not have enough PVDM to enable 30 channels!
Thanks Paolo
Leonardo Santana
Leonardo Santana
Then enable less than that, as incoming from telco only use the lowest ones.
Thank you for the nice rating and good luck!
