12-07-2012 02:28 AM - edited 03-16-2019 02:36 PM
I installed an VWIC3-1MFT-T1/E1 but when i try to configure this module the router says that not exists
#controller e1 0/0/3
% Invalid input detected at '^' marker.
follow the sh diag
i have an 2951 with two PVDM-3 64
Slot 0/0: VWIC3-2MFT-T1/E1(E1)
Slot 0/1: VIC3-2FXS/DID
Slot 0/2: VIC2-4FXO(FXO)
Slot 0/3: VWIC3-1MFT-T1/E1(E1)
sh diag
Slot 0:
C2951 Mother board 3GE, integrated VPN and 4W Port adapter, 12 ports
Port adapter is analyzed
Port adapter insertion time 00:39:18 ago
EEPROM contents at hardware discovery:
PCB Serial Number : FOC15224SHD
Hardware Revision : 1.1
Part Number : 73-11836-06
Top Assy. Part Number : 800-30793-03
Board Revision : D0
Deviation Number : 0
Fab Version : 03
Product (FRU) Number : CISCO2951/K9
Version Identifier : V03
CLEI Code : CMMBM00ARA
Processor type : C8
Chassis Serial Number : FTX1529AK6T
Chassis MAC Address : 30e4.db10.c9e0
MAC Address block size : 96
Manufacturing Test Data : 00 00 00 00 00 00 00 00
EEPROM format version 4
EEPROM contents (hex):
0x00: 04 FF C1 8B 46 4F 43 31 35 32 32 34 53 48 44 40
0x10: 06 15 41 01 01 82 49 2E 3C 06 C0 46 03 20 00 78
0x20: 49 03 42 44 30 88 00 00 00 00 02 03 CB 8C 43 49
0x30: 53 43 4F 32 39 35 31 2F 4B 39 89 56 30 33 20 D9
0x40: 04 40 C1 CB C2 C6 8A 43 4D 4D 42 4D 30 30 41 52
0x50: 41 09 C8 C2 8B 46 54 58 31 35 32 39 41 4B 36 54
0x60: C3 06 30 E4 DB 10 C9 E0 43 00 60 C4 08 00 00 00
0x70: 00 00 00 00 00 F3 00 03 40 01 63 FF FF FF FF FF
0x80: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x90: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0xA0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0xB0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0xC0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0xD0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0xE0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0xF0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Internal Power Supply information
Top Assy. Part Number : 341-0226-02
PCB Serial Number : DCA1524K2NM
RMA Test History : 00
RMA Number : 0-0-0-0
RMA History : 00
Version Identifier : V02
Product (FRU) Number : PWR-2921-51-AC
CLEI Code : 0000000000
Board Revision : A0
0x00: 04 FF 40 05 E2 DF 45 01 55 00 E2 02 88 00 00 00
0x10: 00 C1 8B 44 43 41 31 35 32 34 4B 32 4E 4D 03 00
0x20: 81 00 00 00 00 04 00 89 56 30 32 20 CB 8E 50 57
0x30: 52 2D 32 39 32 31 2D 35 31 2D 41 43 C6 8A 30 30
0x40: 30 30 30 30 30 30 30 30 F3 00 59 41 01 22 42 00
0x50: 05 F8 00 50 01 F3 18 3B 02 F0 19 D9 03 E8 1B 76
0x60: 04 E2 1C 49 05 D9 1D 1B 06 D8 1D ED 07 CF 1E BF
0x70: 08 CE 1F 40 09 C2 1F B8 0A B8 20 34 0B B7 20 B0
0x80: 0D AF 21 0C 0F 9F 21 67 11 91 21 94 13 87 21 C0
0x90: 17 6E 21 DB 1B 57 21 EA 1F 3F 21 E2 23 28 21 D4
0xA0: 27 0A 21 CD 42 41 30 FF FF FF FF FF FF FF FF FF
PVDM Slot 0:
64-channel (G.711) Voice/Fax PVDM3 DSP DIMM PVDM daughter card
Hardware Revision : 1.0
Part Number : 73-11809-03
Board Revision : B0
Fab Version : 03
PCB Serial Number : FOC15255956
RMA History : 00
Processor type : 00
Product (FRU) Number : PVDM3-64
Version Identifier : V01
0x00: 04 FF 40 05 DB 41 01 00 82 49 2E 21 03 42 42 30
0x10: 88 00 00 00 00 02 03 C1 8B 46 4F 43 31 35 32 35
0x20: 35 39 35 36 03 00 81 00 00 00 00 04 00 09 00 CB
0x30: 8F 50 56 44 4D 33 2D 36 34 20 20 20 20 20 20 20
0x40: 89 56 30 31 20 D9 02 40 C1 FF FF FF FF FF FF FF
0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
PVDM Slot 1:
Board Revision : B0
Fab Version : 03
PCB Serial Number : FOC15232DHE
RMA History : 00
Processor type : 00
0x10: 88 00 00 00 00 02 03 C1 8B 46 4F 43 31 35 32 33
0x20: 32 44 48 45 03 00 81 00 00 00 00 04 00 09 00 CB
WIC Slot 0:
VWIC2-2MFT-T1/E1 - 2-Port RJ-48 Multiflex Trunk - T1/E1
Hardware Revision : 0.0
Top Assy. Part Number : 800-22629-05
Board Revision : B0
Fab Version : 04
PCB Serial Number : FOC11521VTL
RMA History : 00
Product (FRU) Number : VWIC2-2MFT-T1/E1
0x00: 04 FF 40 03 FC 41 00 00 C0 46 03 20 00 58 65 05
0x10: 42 42 30 88 00 00 00 00 02 04 C1 8B 46 4F 43 31
0x20: 31 35 32 31 56 54 4C 03 00 81 00 00 00 00 04 00
0x30: CB 90 56 57 49 43 32 2D 32 4D 46 54 2D 54 31 2F
0x40: 45 31 89 56 30 31 20 D9 02 40 C1 FF FF FF FF FF
WIC Slot 1:
3rd generation - FXS DID Voice daughter card (2 port)
Top Assy. Part Number : 800-33587-01
Board Revision : D0
Fab Version : 08
PCB Serial Number : FOC15326E7Z
RMA History : 00
Product (FRU) Number : VIC3-2FXS/DID
CLEI Code : IP9IAB3CAC
Longitudinal Calibration : 01 10 10 95 69 10 10 9E
7A
0x00: 04 FF 40 06 21 41 01 00 C0 46 03 20 00 83 33 01
0x10: 42 44 30 88 00 00 00 00 02 08 C1 8B 46 4F 43 31
0x20: 35 33 32 36 45 37 5A 03 00 81 00 00 00 00 04 00
0x30: CB 8D 56 49 43 33 2D 32 46 58 53 2F 44 49 44 89
0x40: 56 30 33 20 D9 02 40 C1 C6 8A 49 50 39 49 41 42
0x50: 33 43 41 43 D3 09 01 10 10 95 69 10 10 9E 7A FF
WIC Slot 2:
2nd generation - FXO Voice daughter card (4 port)
Hardware Revision : 5.0
Top Assy. Part Number : 800-21589-04
Board Revision : A0
Deviation Number : 0-0
Fab Version : 04
PCB Serial Number : FOC11471LKY
RMA History : 00
Product (FRU) Number : VIC2-4FXO
CLEI Code : CNUIAXJAAB
0x00: 04 FF 40 00 4C 41 05 00 C0 46 03 20 00 54 55 04
0x10: 42 41 30 80 00 00 00 00 02 04 C1 8B 46 4F 43 31
0x20: 31 34 37 31 4C 4B 59 03 00 81 00 00 00 00 04 00
0x30: CB 89 56 49 43 32 2D 34 46 58 4F 89 56 30 33 20
0x40: C6 8A 43 4E 55 49 41 58 4A 41 41 42 FF FF FF FF
WIC Slot 3:
VWIC3-1MFT-T1/E1 - 1-Port RJ-48 Multiflex Trunk - T1/E1
Top Assy. Part Number : 800-34657-01
Part Number : 73-13419-01
Board Revision : A0
Fab Version : 05
PCB Serial Number : FOC15426JHA
Product (FRU) Number : VWIC3-1MFT-T1/E1
CLEI Code : COUIA7PCAA
RMA History : 00
0x00: 04 FF 40 06 ED 41 01 00 C0 46 03 20 00 87 61 01
0x10: 82 49 34 6B 01 42 41 30 88 00 00 00 00 02 05 C1
0x20: 8B 46 4F 43 31 35 34 32 36 4A 48 41 89 56 30 31
0x30: 20 CB 90 56 57 49 43 33 2D 31 4D 46 54 2D 54 31
0x40: 2F 45 31 C6 8A 43 4F 55 49 41 37 50 43 41 41 03
0x50: 00 81 00 00 00 00 04 00 D9 03 40 C1 CB FF FF FF
Embedded Service Engine 0/0 :
Total platform memory : 524288K bytes
Total 2nd core memory : 0K bytes
Start of physical address for 2nd core : 0x20000000
Number of blocks of memory for 2nd core : 1
2nd core configured disabled
L2 cache ways for 2nd core : 0
On the DSP Calc says that i need more PVDM so the module will not work?
Leonardo Santana
Solved! Go to Solution.
12-07-2012 03:53 AM
12-07-2012 03:53 AM
Often asked, had you searched before.
Configure 'card type'.
12-07-2012 04:14 AM
I forgot the card type!
And we do not have enough PVDM to enable 30 channels!
Thanks Paolo
Leonardo Santana
