Wasn't Able to Make Inbound + Outbound Calls (CUCM 11.5 + 2900 ISR)
edy-kurniawan
Hello there.
I already deploy CUCM 11.5 Publisher (76.76.76.151) and CUCM 11.5 Subscriber (76.76.76.154). I got my FXO card and PVDM installed on 2900 Router that act as voice gateway (76.76.76.152). I put my telco line on that FXO port 0 which had a PSTN number (This line is active and when i put it in an analog phone, it can be called) I also have my 3905 + 8865 NR IP phone which is already registered on the CUCM. I can make a call locally, DN to DN. But when i tried to call these extension from outside (from my cell phone to be precise), it won't work. Same as when I try to make the outbound call when I hit the pattern (i set this pattern on the route pattern 9[0]XXXXXXXXXXX).
My question is...
To make the inbound and outbound call work, what am i missing? Thanks so much for your attention sir. I'm quite new to this voice thing
and here is my show run output on the gateway (76.76.76.152)
VoiceGateway#sho run
Building configuration...
Current configuration : 2522 bytes
! Last configuration change at 01:30:20 UTC Thu Nov 15 2018
! NVRAM config last updated at 07:22:07 UTC Fri Nov 16 2018
version 15.2
hostname VoiceGateway
boot-start-marker
boot-end-marker
enable password xxxxx
no aaa new-model
ip cef
no ip domain lookup
no ipv6 cef
voice-card 0
dspfarm
dsp services dspfarm
voice call send-alert
voice rtp send-recv
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
h323
sip
no update-callerid
voice class codec 1
codec preference 1 g711alaw
voice class h323 1
h225 timeout tcp establish 5
h225 timeout setup 5
call preserve
license udi pid CISCO2921/K9 sn FGL173710FW
license boot module c2900 technology-package uck9
hw-module pvdm 0/0
redundancy
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
ip address 76.76.76.152 255.255.255.0
duplex auto
speed auto
h323-gateway voip interface
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 76.76.76.1
control-plane
voice-port 0/0/0
connection plar 10002
caller-id enable
voice-port 0/0/1
caller-id enable
voice-port 0/0/2
voice-port 0/0/3
mgcp profile default
dial-peer voice 10 voip
description To Call Manager UNMUH
destination-pattern [1-5]...
session target ipv4:76.76.76.151
voice-class codec 1
voice-class h323 1
dtmf-relay h245-alphanumeric
no vad
dial-peer voice 100 pots
description To PSTN Trunk
destination-pattern 9T
port 0/0/0
forward-digits all
gatekeeper
shutdown
alias exec c configure term
alias exec sib sh ip inter bri
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
password qwerty
login
transport input all
scheduler allocate 20000 1000
ntp server 76.76.76.101
end
6 Replies 6
run debug cch323 h225 and see if the outgoing call is coming from cucm to
gateway. If yes, post the debug in text file. If not coming then go to dna
in cucm and check call routing
Hello Mohammed,
I just type that command and all i got is "h225 state machine tracing is enabled". No output afterward. I guess I should check my call routing in CUCM. It indicates that there's no route list can route my call from the cell phone. Is it right?
Hi Edy,
As Robert said below, there is no incoming dial peer to accept your call. As an initial configuration, can you do below?
dial-peer voice 1 pots
incoming called-number .
direct-inward-dial
Then do the debug that Mohammed and Robert is asking.
hi Flo
already add that config on my gateway, but i still can't call my internal extension. I run that debug command, but still, the output is none. What should i do? am i miss something on my CUCM?
Robert Shaw
Level 3
Level 3
Firstly, you're missing an Inbound Dial-Peer.  So when you call the number from outside you don't have anything to accept it.  This will by default use a basic Dial-Peer 0.  You need to understand how the Telco is sending the numbers and then you may need to manipulate those digits to send them correctly to Call Manager.
Initially, let's run a test call with the following debugs running on your 2900.
debug voice ccapi inout
This will tell us what digits are coming in and if we need to manipulate them before sending to Call manager.
Rob
thanks, Robert for the answer...as i post above, when i type that debug command, there's no output, just informing me that debug command is ON/active. And you mention about localization, right? is that a must do in call flow? is that a way that i don't do translation. My main goal is, i can make a call with my internal extension, and vice versa. Big thanks for everyone supporting me here. GBU
