Web Access disable after upgrade new fw on 6921
maheshgunaratne
Hi All,
Cannot log in to 6921 phone using IP address after upgrading new fw
Previous Fw - sccp 9.2.1.0
New FW - sccp-9-41-3SR1
Call Manager - 8.6.2
Tried with different browser
tried with disable and enable web access on phone config.
Can access web with previous FW
Any idea how to resolve this.
6 Replies 6
pgupta601
Hi All,
i too am facing this issue.
firmware version:: same.
CUCM version :: 9.1.2
Please help.
Prantik
You'll need to raise a TAC case to progress to a fix if a newer/fixed version of firmware is not available.
Otherwise use the older firmware, or an in-between release (e.g. the oldest one that has the fix for whatever problem cause you to upgrade originally).
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Yes tried, didn't work on explorer 10.
Are you able to access?
I'm going to upgrade cucm to 10.5 so i have to use 9.4(1)SR1
Thanks.
yes it is 10.0.5 internet explorer.
Also my CUCM version is 9.1.2.
Maybe problem with my cucm version 8.6.2
Any idea to resolve this ?
pgupta601
Hi Mahesh,
I tried on internet explorer and it works fine.
Could you check on Internet Explorer?
