when i add command service aa on dial-peer voice pots line goes to busy?
            Hi all, when i add command service aa on dial-peer voice X pots line goes to busy?
Chris Deren
Did you configure your AA application properly?  When you add this command then AA TCL script gets invoked, is you are getting busy it means you did not properly configure the application on your router.
HTH,
Chris
iit's router config; plz cheak it:
application
service aa flash:app-b-acd-aa-2.1.2.2.tcl
  param number-of-hunt-grps 2
  paramspace english index 1
  param menu-timeout 6
  param dial-by-extension-option 5
  param handoff-string aa
  paramspace english language en
  param max-time-vm-retry 2
  param max-extension-length 4
  param aa-pilot 38888
  paramspace english location flash:
  param second-greeting-time 60
  param welcome-prompt en_bacd_welcome.au
  param call-retry-timer 1
  param max-time-call-retry 1
  param voice-mail 5000
  param service-name queue
service queue flash:app-b-acd-2.1.2.2.tcl
  param queue-len 30
  param aa-hunt1 1200
  param queue-manager-debugs 1
  param aa-hunt2 2100
