Why Cannot Connect Cisco 7975G IP Phones to Cisco 2911 router
angelo castro
HI Everybody,
I need Assistance why Cisco 7975G cannot connect to cisco 2911 router.
Before the router I connect first to unmanaged POE switch.
I attach configuratipn of the router.
Angelo
Chris Deren
Are other phones working?
What is the issue?
Is phone getting IP address and proper TFTP?
Have you looked at debug ephone register to see what is going on?  debug tftp-events?
Hi Chris,
Phone not Working.....
Issue is phone Show only Connecting
I'm think not getting IP address and proper TPTP.
I'm using Cisco Configuration Professional and not familiar with cisco ios command
Angelo
What IP address is the IP phone getting ? Have a look at the menu Parameters > Network Configuration > IPv4 Configuration > IP address.
How did you configure the trunk port between the router and the switch ?
How did you declare the vlans in the switch ? Did you declare the voice vlan on the switch and affected the Interfaces to that voice vlan ?
If the switch is not manageable, then I think you have to work with the Native vlan, and add the option 150 (TFTP) to the DHCP pool of the native vlan (which is VLAN 1 in your config).
Phone IP Address show 192.168.40.8
and this my setting
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
ip address 192.168.100.1 255.255.255.0
ip nat inside
ip virtual-reassembly in
duplex auto
speed auto
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0/2
no ip address
duplex auto
speed auto
interface GigabitEthernet0/2.1
encapsulation dot1Q 1 native
ip address 192.168.40.1 255.255.255.0
interface GigabitEthernet0/2.10
encapsulation dot1Q 10
ip address 10.1.3.1 255.255.255.0
ip pim dense-mode
interface GigabitEthernet0/2.30
encapsulation dot1Q 30
ip address 10.7.1.1 255.255.255.0
interface GigabitEthernet0/2.50
encapsulation dot1Q 50
ip address 10.1.1.10 255.255.255.0
interface GigabitEthernet0/2.100
description $ETH-LAN$
encapsulation dot1Q 100
ip address 10.1.5.1 255.255.255.0
ip pim dense-mode
ip nat inside
interface Serial0/0/0:23
description MainCon
no ip address
encapsulation hdlc
isdn switch-type primary-net5
isdn incoming-voice voice
no cdp enable
What is the command to the
im just beginner on cisco ios command. now im using CCP.
Angelo
