09-09-2009 06:10 AM - edited 03-15-2019 07:41 PM
Below is warnng
#WARNING: gw-accounting fact not enabled. return.WARNING: gw-accounting fact not enabled. return.
09-09-2009 06:15 AM
Below is my configurations
gw-accounting file
primary ftp 164.4.249.82 username ben98 password 123456
maximum buffer-size 40
maximum fileclose-timer 60
maximum cdrflush-timer 45
cdr-format compact
03-30-2010 01:09 PM
I have the exact same issue on ISR2811 with 12.4.24 (T). were you able to figure out what the problem was?
03-30-2010 02:27 PM
CSCtb72550 Bug Details
Call Detail Record File not created in FTP Server
Symptoms: Call Detail Record (CDR) files pushed via FTP are not created on the FTP server.
Conditions: This symptom is observed when the gw-accounting file command is configured to point to an FTP server.
Workaround: Push the CDR records locally to the flash instead of to an FTP URL
03-30-2010 07:11 PM
is there a way to periodically move the file from flash to fTP?
03-31-2010 01:38 AM
No.
03-31-2010 01:45 AM
Well - you could maybe use a scheduled EEM script to copy the output file?
03-31-2010 02:25 AM
So to avoid a simple image upgrade one starts tinkering workarounds ?
03-31-2010 02:34 AM
Now now... question was 'could I', no 'should I'...
03-31-2010 02:49 AM
In that sense, Expect scripting predates EEM by 20 years, and work great.
But fortunately, not even Cisco dares to suggest that as workaround.
03-31-2010 06:59 AM
wow ok. so the best option is to upgrade. do you know if this has been fixed in 12.4.22YB4? thanks a lot for all your help guys.
03-31-2010 11:04 AM
Hi Kris,
Just an FYI 12.4.22YB4 is in the "known affected version list" as shown in the link below
Here are the "fixed-in" versions
Fixed-In
15.1(0.21)T
12.2(32.8.11)SX332
12.2(32.8.11)YST273.11
12.4(24)YE
15.1(24.6.26)PIL13
15.0(1)M1.7
15.1(0.2.12)PIB13
12.4(25b)M0.18
12.4(24)T3
15.1(1)XB1
15.1(0.0.10)PIL14
Cheers!
Rob
Please support CSC Helps Haiti
10-15-2012 05:29 AM
Hi, everyone.
I have the same problem.
My IOS version is Version 15.1(4)M4
And I cant send the CDR files to the FTP Server.
Here is are my commands:
gw-accounting file
primary ftp
:[ ]/BibCme1/cdrtest1 username password secondary ifs flash:cdrtest2
acct-template callhistory-detail
maximum buffer-size 25
maximum retry-count 5
maximum fileclose-timer 500
maximum cdrflush-timer 445
cdr-format compact
Where:
/BibCme1 is the FTP (See the image)
cdrtest1 is the filename.
Putting the CDR on flash memory works, but I cant get it to work on the FTP Server that I need to configure the billing software (BillyBlues - Stonevoice Application Suite 2012).
Any help??
Or is there a way that I can copy the CDR from flash to FTP Server???
I have added the following command to force CME to send CDRs to BillyBlues too:
file-acct flush with-close
But I still cant do it.
Any help?
Edson Vuma
07-03-2011 05:33 AM
Please try this:
R(config)#gw-accounting file
primary ftp BillyBlues_IP/billyblues/ username usr password pwd
maximum buffer-size 6
maximum retry-count 4
maximum fileclose-timer 300
where
• BillyBlues_IP is the IP address of the BillyBlues machine
• usr/pwd is the username/password of the local Administrator on the BillyBlues machine.
The following command to force CUCME to send CDRs to BillyBlues:
R# file-acct flush with-close
R# file-acct reset
