Why using trust at interface ?
eigrpy
Level 4
Level 4
Hi It looks like that all interface for voip traffic need to be trusted first. Why using the trust ? I think trust configuration can delete all previous mark and start new mark at the interface ? Am I right ? Any one can confirm it or correct it for me ? Thank you
Chris Deren
What trust are you talking about? Please elaborate, is this QoS trust, toll-fraud prevention trust, something else?
Sorry.for example, we use the following command for trust configuration for Qos
3560Switch(config-if)#mls qos trust dscp
Well, that is not what you would apply to host switch-port, only router, switch uplink as this creates unconditional trust from the port.  QoS on switches depends on switch model and QoS end to end strategy, which you can learn more about in Cisco medianet SRND:
http://www.cisco.com/c/en/us/td/docs/solutions/Enterprise/WAN_and_MAN/QoS_SRND_40/QoSCampus_40.html
