WiFi Voip application
Theodore April
HI
I need some direction please
im new into voip - ccnp routing and switching
I’m looking for direction
Does Cisco have a call manager that allows you to make calls via mobile phone using an application when connected to your corporate WiFi
Alternatively when you out of office all your calls is diverted to mobile number ?
Theodore
Jaime Valencia
Yes, you can install Jabber on iOS and Android to place calls as any other IP Phone, and you can use either MRA or SNR when you're outside the office.
java
if this helps, please rate
i need that
You may read the following and of course plenty of material on Community
https://www.cisco.com/c/en/us/products/unified-communications/jabber/index.html
George
Please Rate Posts (by clicking on Star) and/or Mark Solutions as Accepted, when applies
