04-15-2013 10:53 PM - edited 03-16-2019 04:49 PM
Dear All,
I am running cisco call manager 8.5.
the issue is that the wireless ip phone 7926 is not registering with the call manager.
the issue seems to be with the firmware all the settings in the wireless ip phone are fine.
Please find the attached screen shoots
please guide me how i can upload the firmware and fix this issue
Malik
Solved! Go to Solution.
04-16-2013 02:10 AM
Hi Malik,
Just restart the TFTP service on server where u have uploaded LOAD.Accordingly,check for registration of 7926G
After that , u need to upload firmware on all servers in a cluster and restart TFTP service
regds,
aman
04-15-2013 11:03 PM
Hi Malik,
What is the firmware u are running in Call Manager for 7926G?
You need to have LOAD cmterm-7926-sccp.1-4-4-3.cop.sgn
Refer the README file
http://www.cisco.com/web/software/282074289/52353/cmterm-7926-sccp.1-4-4-3-Readme.html
also, provide the snapshots which I suppose u have missed.
regds,
aman
04-15-2013 11:21 PM
04-15-2013 11:28 PM
Hi Malik,
Snapshot shows u have just added phone in call manager.Any error u get on the phone.
Can u check for the Firmware using command file list tftp *7926* from OS Administration using putty?
regds,
aman
04-15-2013 11:40 PM
Hi Aman,
This is the current firmware CP7926G-1.4.2
Regard,
Malik
04-15-2013 11:47 PM
Hi Malik,
You need to go for below firmware:
CUCM Release | Cisco 7926 Firmware Installer | MD5 Hash |
7.1(5) and later | cmterm-7926-sccp.1-4-4-3.cop.sgn | 2d:de:1f:42:79:9d:23:2b:c9:fe:5c:a8:01:4d:09:80 |
Use the URL to download the image:
regds,
aman
04-16-2013 01:53 AM
04-16-2013 02:10 AM
Hi Malik,
regds,
aman
04-18-2013 09:35 AM
thanks a lot AMAN
04-18-2013 09:37 AM
Hi Mailk,
Good...problem is resolved.
regds,
aman
