11-22-2007 09:47 AM - edited 03-15-2019 07:22 AM
Hi all,
Why my 7970G is displaying wrong time while all others are with the right time?
I'm using ccme4.2, the load file on my 7970 is SCCP70.8-2-2SR2S, my ios is 12.4(11)XW2.
I've set the time-zone parameter on telephone-service.
This issue is driving me Crazzzzy.
Thanks in advance.
11-22-2007 04:16 PM
can you try XW4 and 8.2(2)SR4S ?
Eg. it works fine for me with 12.4(11)XJ4.
11-23-2007 12:37 AM
Rafael,
Same type of issue with CCME 4.0, but with 7911 phones. Even the updated firmware doesn't work. Only solution seems to be to upgrade the router IOS. We are planning to implement that soon in our place. I shall keep you posted if it resolves our issue.
Abhijit Das.
11-23-2007 07:30 AM
Hello Rafael ,
I think Upgrading the 7970 Firmware to Higher Version will solve the Problem. It worked with me.
M.Tag
