IP Telephony and Phones
Labels
e1
i have a call manager that connect to a gateway router and the router connect to e1 this e 1 has 100 numbers like from 55812.. to 5581299 i need when someone call 5581250 go to the fax which connect to fxs port exist on the router how can i do that
I have a location where all of the phones now have only a couple ring tones. After the installation the phone had a number of ring tones. What can cause this and how are ring tones downloaded to the phones they have 7960's and 7961's
248SHaune by Level 1
  • 359 Views
  • 1 replies
Hello - I have CCM 4.2(3) and a 3845 MGCP gateway. Between the gateway and my legacy IVR (Edify Workforce) I have a T1-CAS circuit. I can successfully place a call into my IVR. My IVR has a script that allows me to input an extension and be transferr...
jaywydra by Level 1
  • 2108 Views
  • 18 replies
HiI am running MGCP controlled gateway with fall back to h323. But, after disable serial cable from the link to CCM, I still cant see srst kick in. Is there bug in IOS Or any issues like that.I am using AdvancedIPServiceK9 release 12.4(3g) on 3845.Th...
guest by Level 1
  • 763 Views
  • 15 replies
