03-29-2012 08:47 AM - edited 03-16-2019 10:22 AM
My company currently has a solution that was implemented approximately 6 months ago and has worked great until recently.
We have a couple of sites that "all of a sudden" cannot fax us. The strange thing is we can receive faxes from anyone else but these couple of sites.
We've received 130+ faxes since this time yesterday from other entities.
These sites appear to have issues faxing to any of our numbers associated with our PRI. I have put a physical fax machine with an analog line (using same carrier as our PRI) and faxes come through successfully.
Our setup:
- xMedius Fax Server = 172.20.1.101
- Voice Gateway = 172.20.1.98
Voice Gateway CISCO3825 running 12.4(13r)T |
dial-peer voice 8010 voip description FAX Dial-Peer destination-pattern 8010 session target ipv4:172.20.1.101 *** 172.20.1.101 = xMedius Server *** dtmf-relay h245-signal codec g711ulaw fax rate 14400 fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback cisco |
I've attached capture from the xmedius server.
03-29-2012 11:27 AM
Try to decrease the fax speed to 9600 bps, disable error correction (ecm), disable non standard facilities and disable vad using these commands:
modem passthrough nse codec g711ulaw
fax-relay ecm disable
fax rate 9600
fax nsf 000000
fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback pass-through g711ulaw
no vad
You can also debug the fax transmission using the command "debug fax relay t30 all".
Post the output.
Regards.
03-29-2012 11:28 AM
You can also try to upgrade IOS. Sometimes help.
Regards.
03-29-2012 12:49 PM
Who is the carrier and when did it start? We have the same issue the carrier is Century Link. We have 4 T1 pri's and have the exact same issue. It started last Friday. We have already performed the iOS upgrade.
03-29-2012 01:02 PM
The loal carrier in our town is CenturyLink so I'm pretty sure the sources of the faxes are CenturyLink.
My 3 PRIs are Cox Communication. I didn't find out about it until late Monday or Early Tuesday, but have been banging my head against a wall.
- I have had a case open with xMedius Support - they turned me over to Cisco
- I then opened a TAC case with Cisco. they are rreviewing captures from erlier today. I'm hoping to hear something soon.
- I have also started to engage Cox Communiations.
This does appear to be a carrier problem though if you are having the same issue.
Are you in the SE? I'm located in Centra Florida.
My IOS is actually: flash:c3825-spservicesk9-mz.124-24.T6.bin
I was going to update to: flash:c3825-spservicesk9-mz.124-24.T7.bin ** Not sure this will make a difference **
I'm in the middle of trying the suggesions bove but it just "all of a sudden stopped wrking" for these sites.
Thanks for the replies.....
03-29-2012 01:06 PM
I'm in Arizona. We also are going through TAC. I'm going to let my guys know about this. Are you getting any complaints of static or low volume?
Gene
Sent from my iPhone
03-29-2012 01:12 PM
As a company, our call qualities are good "knock on wood", but our PRI carrier is not CenturyLink. We just moved away from hem 6 months ago. However, our local businesses faxing are on CenturyLink for the most part and are upset with us not receiving their faxes. They can fax anyone else, however, their other destinations are probably on CenturyLink as well.
WOW... whata mess...
Greg
03-29-2012 01:17 PM
Always is when you have to include the carrier. It's never their problem (at least they never admit it)
Good luck
Sent from my iPhone
03-29-2012 08:35 PM
If you hear anything on a fix, please share as I will do the same.
Greg
03-29-2012 08:38 PM
We have Century Link performing intrusive testing tonight on all 4 T1's. I'll let you know if they find a problem.
Sent from my iPhone
03-30-2012 04:28 AM
I received this from TAC this AM.
Hello Greg,
I included my analysis and the audio for a failed fax.
Basically the fax tones coming from telco are not being recognize and the fax server sends several times a DIS (Digital Identification Signal) and it never gets a response. This is the same behavior seen in the packet capture taken in the fax server. Unfortunately the working packet capture was corrupted but basically the correct T30 signaling is not ok. We can schedule a time when there is low volume to work on getting a working capture for comparison with the not working.
The suggestion is to get in touch with the provider since the Gateway is not getting the correct T30 tones from the originating fax.
I sent the findings to my Cox guys and hopefully they can look into the situation also and help.
FYI - My Gateway has 3 PRIs from Cox Communications. However, the faxes are sourcing from businesses with CenturyLink as their carrier.
03-30-2012 04:55 AM
Greg,
That's interesting. The analysis we got from TAC for our failed fax calls was pretty much the same as what you got.
The testing by CL last night didn't show up any errors on the T1's and to be honest I didn't think it would. I'm on my way in early this morning to cold start the gateway.
What Cisco device are you using for a vgwy? I think I saw 36xx?
I think my next move is to swap out the vgwy with a spare and see if it is resolved.
Gene
Sent from my iPad
03-30-2012 06:20 AM
Gene,
That is very strange that our problems occured pretty much at the same time with what appears to be the same carrier. I have escalated this to Cox Communications (our PRI carrier) to look through the analysis from TAC. I am planning on trying to call CL to see I can get anywhere with them also. The problem is I do not have any CL accounts as we moved away from them 6 months ago. I may have to have my customers / end users give CL a call as well...
Please let me know if swapping works for you as I do not have the flexibility to swap out the vgwy.
My Voice Gateway is:
NAME: "3825 chassis", DESCR: "3825 chassis"
NAME: "VWIC2-2MFT-T1/E1 - 2-Port RJ-48 Multiflex Trunk - T1/E1 on Slot 0 SubSlot 0", DESCR: "VWIC2-2MFT-T1/E1 - 2-Port RJ-48 Multiflex Trunk - T1/E1"
NAME: "VWIC2-2MFT-T1/E1 - 2-Port RJ-48 Multiflex Trunk - T1/E1 on Slot 0 SubSlot 1", DESCR: "VWIC2-2MFT-T1/E1 - 2-Port RJ-48 Multiflex Trunk - T1/E1"
NAME: "PVDMII DSP SIMM with three DSPs on Slot 0 SubSlot 4", DESCR: "PVDMII DSP SIMM with three DSPs"
PID: PVDM2-48
NAME: "PVDMII DSP SIMM with three DSPs on Slot 0 SubSlot 5", DESCR: "PVDMII DSP SIMM with three DSPs"
PID: PVDM2-48
03-30-2012 10:28 AM
Greg,
We gave CL the phone numbers we were having problems with an they are all Cox numbers. They are now looking at the link they have with Cox. It could be an issue between the two of them and we got caught in the middle.
Gene
04-03-2012 08:45 AM
Gene,
Are you still experiencing this problem?
