Zeacom Call center and Cisco CM integration
satish farande
Hello ,
I'm looking for the integration guide for Zeacom Call center and Cisco CM integration.
Did search on internet but no luck . can any one help me with link or document for same.
Thanks & Regards
Deepak Rawat
Why don't you reach out to Zeacom support asking for the integration requirement with CUCM. There could be any kind of requirment such as TSP, JTAPI/CTI, AXL integration may be a SIP trunk required as well. CUCM can support all the above mentioned integration that are usually required with a Call Center environment.
Hence, reach out to Zeacom and ask what exactly they are looking for.
Deepak
Thank you all , for support.
on zeacom website they have metion integration of their contact center product with cisco CM and tested with cisco developer team. I was looking for any application or document  with integration example.
Thanks & Regards
Satish
devils_advocate
Level 7
Level 7
If you did a search on the internet and found nothing then its likely not a common integration and the chances of somebody on here having done it and stumbling across this post is very slim.
As Deepak mentioned, perhaps Zeacom have a guide or have someone on staff who has done the integration before?
Have Zeacom got any guides on how to integrate with other Call Manager systems?
Dennis Mink
It is possible, I know an organisation that integrated it into CUCM 10.5. Like other people already mentioned, address this with Zeacom.
http://www.zeacom.com/nz-parent-menu-solutions/partner-platforms/cisco/uc-manager-business-edition
Please remember to rate useful posts, by clicking on the stars below.
