IPv6
Get 20% off switches when you combine Cisco solutions
After spending the weekend deploying IPv6 on an MX using a provider independent IPv6 allocation, I've come away wondering why enterprise IPv6 still feels like an afterthought in 2026.Good:SLAAC works.Clients immediately receive global IPv6 addresses....
The_Phil by • Community Member
  • 845 Views
  • 4 replies
  • 2 Helpful votes
Hello all,I have a question regarding an SRv6 deployment.On a Cisco N540-12Z20G-SYS-D running Cisco IOS XR Software Version 25.4.1, what is the recommended way to verify whether traffic is actually being forwarded over an SRv6 TE policy?I would like ...
in IOS XE, the DHCPv6 relay only requires one command: ipv6 dhcp relay destination 2222:db8:0:22::24it does not require setting M flag and the client receives only A flag from the relay agent.ICMP6, router advertisement, length 64hop limit 64, Flags ...
daniel ng by • Spotlight
  • 1692 Views
  • 6 replies
We are testing IPv6 in our environment.  We are experiencing an issue with default gateway on end devices with static IP address. The end devices do not pick up the IPv6 default gateway on the 9200L switches. The end devices connected to other switch...
smartengr3 by • Community Member
  • 1027 Views
  • 4 replies
Hello allI tried to test OSPFv3, but it has no connection bitween each other.What should change?Thank in advnace'''''''''''''''R0#ipv6 unicast-routing!interface GigabitEthernet0/0ipv6 address 2000:ABCD:1111:A:1::/64ipv6 enable!interface GigabitEthern...
Hi, Can someone help me understand what I am doing wrong here? I try to configure eBGP using this guide: https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/iproute_bgp/configuration/xe-16/irg-xe-16-book/ipv-routing-multiprotocol-bgp-link-local-address...
HelloThe PC0 ip address 2000:1111:ABCD:2:11::/64 can not connectThe PC1 ip address 2000:1111:ABCD:3:11::/64. What should I change?Thanks in advanceQu R1#ipv6 unicast-routinginterface GigabitEthernet0/0/0ipv6 address 2000:1111:ABCD:1:1::/64ipv6 rip 1 ...
Hi everyone  I have a server on the internal network that needs to be published with an IPv6 address. Therefore, I need a device that can perform IPv6 to IPv4 translation for me. It's for a single IPv4, so I need it to be the smallest device. I under...
gfacelli by • Frequent Visitor
  • 1471 Views
  • 3 replies
TL;DR: After migrating from ASR9Ks to NCS-57B1s (IOS-XR 7.10.2), four IPv6 PNIs to the same provider flap across four different devices. ND stays REACH, but IPv6 echo and BGP TCP/179 stall. Clearing the IPv6 neighbor cache brings it back for ~4–5 min...
swahlmark by • Visitor
  • 3342 Views
  • 11 replies
Hello All,I'm a bit confused on the use cases for this and whether they can be used interchangeably or not. My current configuration is legacy to me for Stateful IPv6 DHCP and includes the following configuration:ipv6 nd prefix default no-autoconfigi...
DomTurchi by • Community Member
  • 6113 Views
  • 6 replies
