MediaSense Search and Play Wildcard
villarrealed
I've tried to use wildcards such as *1234 when using MediaSense Search and Play with no luck.  Can wildcards be used in the MediaSense search and play application?
Anil Verma
Level 5
Level 5
Wildcard searches are not current supported in the MediaSense Searches via the GUI pr through the API on most search parameters.
You can use the wildcard to search for Tags only, not any other fields like Participant extensions etc.
We are looking into building this out for a future release.
Anil Verma
Level 5
Level 5
