bfd configuration for ipv6 bgp
sachin30720041
Hello All,
I am trying to configure BFD for ipv6 BGP. BFD session is not up. Am I missing any configuration?
R1-----R2
R1
ipv6 unicast-routing
int gi1
ipv6 enable
ipv6 address 2001:face::1/64
ip address 100.10.20.1 255.255.255.0
no sh
bfd-template multi-hop bfd1
interval min-tx 1000 min-rx 1000 multiplier 4
exit
bfd map ipv6 2001:face::2/128 2001:face::1/128 bfd1
router bgp 1
neighbor 2001:face::2 remote-as 2
neighbor 2001:face::2 fall-over bfd multi-hop
address-family ipv6 unicast
neighbor 2001:face::2 activate
exit
R2
int gi1
ipv6 enable
ipv6 address 2001:face::2/64
ip address 100.10.20.2 255.255.255.0
no sh
exit
bfd map ipv6 2001:face::1/128 2001:face::2/128 bfd1
router bgp 2
neighbor 2001:face::1 remote-as 1
neighbor 2001:face::1 fall-over bfd multi-hop
neighbor 2001:face::1 activate
Sachin
balaji.bandi
Is this Lab or a real environment?
have you seen this command executed?
my lab it taking maximum : (999)
interval min-tx 999 min-rx 999 multiplier 4
here is up bot the side (same config of yours)
BB
Harold Ritter
Hi @sachin30720041 ,
This is not a multi hop bfd session as the two routers are directly connected. You need to add the following under the interface and change your bgp config.
R1:
int gi1
bfd interval 1000 min_rx 1000 multiplier 4
router bgp
R2:
int gi1
router bgp
If you want to test BFD multi hop, you need to insert a router in between R1 and R2. Also, remember that "neighbor fall-over bfd multi-hop" will not work unless configured along with the "neighbor ebgp-multihop" statement.
