GRE on MPLS
mailaglady2
Network diagram
CE --- PE1 --- PE2
|---Tunnel int--|
Tunnel Interface
I have an MPLS cloud between the PE routers, now my problem is I have a loopback1001(PE2) that is on a vrf and I can ping it from the CE router. On the CE router I also have a loopback interface and I can also ping the CE loopback from a PE2 vrf instance. I have created a tunnel interface with a source and destination of both loopbacks but I cannot ping the tunnel.
I have tried to add the tunnel interface on the VRF instance and I also tried to remove the vrf on the tunnel interface but I still can't ping the tunnel, what could be a problem here?
Kind regards
Mpho
Roman Rodichev
Level 7
Level 7
on PE2, you need command "tunnel vrf X" under the tunnel interface. You want the tunnel to look for source and destination inside VRF
5 Replies 5
Yasir Ashfaque
its quite confusing topology, have you configured the VRF on PE2? (Bypassed PE1 through Tunnel) you need to share configs to understand it more.
Roman Rodichev
Level 7
Level 7
Thanks for your assistance, i only need the command "tunnel vrf X" and it's now working.
Do you perhaps have a url or a document that I can read to get more details on how to configure and verify this, I need to add ipsec on this tunnel now.
Thanks a lot.
