Help Can not configure output service policy
garth.gordon
PE5-MAL-BE(config-if)# service-policy output ccna-sp-nan1-out-MIPS
I/f Serial1/1 class class-default requested bandwidth 34360 (kbps) Available only 34002 (kbps)
interface Serial1/1
mtu 1500
no ip address
encapsulation frame-relay IETF
no ip mroute-cache
logging event subif-link-status
logging event dlci-status-change
tx-ring-limit 56
max-reserved-bandwidth 100
service-policy input ccna-sp-nan1-in-MIPS
framing g751
dsu bandwidth 34010
clock source internal
serial restart-delay 0
frame-relay lmi-type ansi
frame-relay intf-type dce
romccallum
Level 4
Level 4
what does your policy map look like
You cant use more than 75 percent of total bandwidth for QoS. Here is a TAC case that describes the issue and discusses a workaround.
http://www.ciscotaccc.com/atm/showcase?case=K15701684
spremkumar
Level 9
Level 9
hi
As exactly pointed out by the other poster you wont be able to configure more than 75% of the total B/W available if u wanna do more than that better you can check out for max-reserved-bandwidth command undder the particular where you are trying to apply the policy map.
but do take care and plan accordingly about the minimum b/w requirement for the routing protocol updates etc.,
do refer this link too for more info on the same..
http://www.cisco.com/univercd/cc/td/doc/product/software/ios121/121cgcr/qos_r/qrdcmd3.htm#wp1023531
regds
Do "show interface" on your Serial interface and see the bandwidth set on the interface. You have configured 'max-reserved-bandwidth' to be 100%, but still it's not enough and you're oversubscribing with you QoS reservation :-(
You can either set the bandwidth on the interface to a higher value (be careful not to overscribe the actual bandwidth or you will queue and potentially drop packets when you apply QoS for 100% of bandwidth) or reserve less bandwith in your policy-map.
David
