Help - core LSP broken - unusable: no label
antione-smith
Hola.
Need quick help to identify where MPLS LDP issue is, PE to P, take a look below, can be quick fix, but interesting issue.
I have 7606 MPLS PE router, IOS Version 12.2(33)SRC4, with following mods:
1-subslot SPA Interface Processor-600  7600-SIP-600 <--- link to P router
Supervisor Engine 720 (Active)         WS-SUP720-3BXL
Directly connected to 12416/PRP MPLS P router, Version 3.5.2, at remote site via optical DWDM.
0/8/CPU0        PRP(Active)     N/A             IOS XR
0/10/0          SPA             SPA-10X1GE-V2
7606 was recently fully reconfigured for restoration after full site outage and MPLS vpn forwarding plane lost connectivity since.
PE1#sh mpls interf
Interface              IP            Tunnel   BGP Static Operational
GigabitEthernet1/0/0   Yes (ldp)     Yes      No  No     Yes
PE1#ping vrf 65001 10.120.4.1 repeat 2        <-- L3vpn interface on remote PE
Sending 2, 100-byte ICMP Echos to 10.120.4.1, timeout is 2 seconds:
Success rate is 0 percent (0/2)
PE1#sh ip cef vrf 65001 10.120.4.1
10.120.4.0/27
  nexthop 10.100.104.181 GigabitEthernet1/0/0 unusable: no label
PE1#trace mpls ipv4 10.100.100.2 255.255.255.255
Tracing MPLS Label Switched Path to 10.100.100.2/32, timeout is 2 seconds
Codes: '!' - success, 'Q' - request not sent, '.' - timeout,
  'L' - labeled output interface, 'B' - unlabeled output interface,
  'D' - DS Map mismatch, 'F' - no FEC mapping, 'f' - FEC mismatch,
  'M' - malformed request, 'm' - unsupported tlvs, 'N' - no label entry,
  'P' - no rx intf label prot, 'p' - premature termination of LSP,
  'R' - transit router, 'I' - unknown upstream index,
  'X' - unknown return code, 'x' - return code 0
  0 10.100.104.182 MRU 0 [No Label]
Q 1 *
PE1#sh run int GigabitEthernet1/0/0
interface GigabitEthernet1/0/0
 description Connection to P1
 mtu 9180
 ip address 10.100.104.182 255.255.255.252
 ip ospf message-digest-key 1 md5
 ip ospf network point-to-point
 speed nonegotiate
 mls qos trust dscp
 mpls traffic-eng tunnels
 mpls ip
 bfd interval 100 min_rx 100 multiplier 3
Control plane looks normal
PE1#sh ip route vrf 65001 10.120.4.1
Routing Table: 65001
Routing entry for 10.120.4.0/27
  Known via "bgp 65500", distance 200, metric 0, type internal
  Last update from 10.100.100.2 03:55:00 ago
  Routing Descriptor Blocks:
  * 10.100.100.2 (default), from 10.100.100.4, 03:55:00 ago
      Route metric is 0, traffic share count is 1
      AS Hops 0
      MPLS Required
PE1#sh mpls ldp neigh 10.100.100.2 detail    <-- remote PE router
    Peer LDP Ident: 10.100.100.2:0; Local LDP Ident 10.100.100.214:0
        TCP connection: 10.100.100.2.646 - 10.100.100.214.34284
        Password: not required, none, in use
        State: Oper; Msgs sent/rcvd: 2288/739; Downstream; Last TIB rev sent 1138
        Up time: 06:42:10; UID: 10476; Peer Id 2;
        LDP discovery sources:
          Targeted Hello 10.100.100.214 -> 10.100.100.2, active, passive;
            holdtime: infinite, hello interval: 10000 ms
        Addresses bound to peer LDP Ident:
          10.100.100.2    10.10.1.90      10.10.2.223     10.100.111.1
          10.100.101.49   10.100.115.5    10.100.101.57   10.100.101.69
          10.100.111.254  10.100.101.2
        Peer holdtime: 180000 ms; KA interval: 60000 ms; Peer state: estab
        Clients: Dir Adj Client
PE1#sh run | sec mpls
mpls ldp neighbor 10.100.100.1 password 7 130603304F5D1407
mpls ldp graceful-restart timers max-recovery 600
no mpls ip propagate-ttl forwarded
mpls label protocol ldp
  match mpls experimental topmost 1  3  6
  match mpls experimental topmost 5
  match mpls experimental topmost 4
 neighbor 10.100.100.129 encapsulation mpls
 neighbor 10.100.100.220 encapsulation mpls
 neighbor 10.100.100.75 encapsulation mpls
 neighbor 10.100.100.193 encapsulation mpls
 neighbor 10.100.100.83 encapsulation mpls
 neighbor 10.100.100.203 encapsulation mpls
 neighbor 10.100.100.2 encapsulation mpls
 neighbor 10.100.100.136 encapsulation mpls
 neighbor 10.100.100.3 encapsulation mpls
 neighbor 10.100.100.14 encapsulation mpls
 neighbor 10.100.100.5 encapsulation mpls
 neighbor 10.100.100.8 encapsulation mpls
 neighbor 10.100.100.65 encapsulation mpls
 neighbor 10.100.100.11 encapsulation mpls
 neighbor 10.100.100.12 encapsulation mpls
 neighbor 10.100.100.73 encapsulation mpls
 neighbor 10.100.100.138 encapsulation mpls
 neighbor 10.100.100.132 encapsulation mpls
 neighbor 10.100.100.134 encapsulation mpls
 neighbor 10.100.100.218 encapsulation mpls
 mpls ip
 mpls ip
 mpls ip
 xconnect 10.100.100.3 4056 encapsulation mpls
  backup peer 10.100.100.2 4055
 xconnect 10.100.100.3 3056 encapsulation mpls
  backup peer 10.100.100.2 3055
 xconnect 10.100.100.3 5104 encapsulation mpls
 xconnect 10.100.100.3 5105 encapsulation mpls
 mpls traffic-eng router-id Loopback0
 mpls traffic-eng area 0
 mpls traffic-eng multicast-intact
 neighbor mpls_peer peer-group
 neighbor mpls_peer remote-as 65500
 neighbor mpls_peer update-source Loopback0
 neighbor 10.100.100.4 peer-group mpls_peer
 neighbor 10.100.100.66 peer-group mpls_peer
  neighbor mpls_peer send-community extended
snmp-server enable traps mpls ldp
snmp-server enable traps mpls vpn
mpls ldp router-id Loopback0
------------ P router -------------------
P1#sh mpls interf
Interface                  LDP      Tunnel   Enabled
GigabitEthernet0/10/0/2    Yes      No       Yes
P1#sh run int GigabitEthernet0/10/0/2
interface GigabitEthernet0/10/0/2
 description "Connection to PE1 gi1/0/1"
 cdp
 mtu 9194
 ipv4 address 10.100.104.181 255.255.255.252
 load-interval 30
P1#sh mpls ldp neigh brief
Peer              GR Up Time         Discovery Address
10.100.100.23:0   Y  21w6d                   2       9
10.100.100.2:0    Y  21w6d                   1      10
10.100.100.11:0   Y  21w6d                   1       3
10.100.100.64:0   Y  20w4d                   1       6
10.100.100.128:0  Y  5w4d                    1       4
10.100.100.12:0   Y  3w5d                    1       3
10.100.100.32:0   N  4d17h                   1       3
P1#sh mpls ldp neigh 10.100.100.214   <--- no output for LDP adjacency for PE1
Peer LDP Identifier: 10.100.100.2:0
  TCP connection: 10.100.100.2:43822 - 10.100.100.1:646; MD5 on
  Graceful Restart: Yes (Reconnect Timeout: 120 sec, Recovery: 0 sec)
  Session Holdtime: 180 sec
  State: Oper; Msgs sent/rcvd: 255213/255123
  Up time: 21w6d
  LDP Discovery Sources:
    TenGigE0/0/0/0
  Addresses bound to this peer:
    10.10.1.90      10.10.2.223     10.100.100.2    10.100.101.2
    10.100.101.49   10.100.101.57   10.100.101.69   10.100.111.1
    10.100.111.254  10.100.115.5
P1#sh run
mpls ldp
 router-id 10.100.100.1
 log
  neighbor
  graceful-restart
 discovery targeted-hello accept
 graceful-restart
 graceful-restart reconnect-timeout 300
 graceful-restart forwarding-state-holdtime 600
 neighbor 10.100.100.2 password encrypted 011012261F5A1622
 neighbor 10.100.100.3 password encrypted 110A0D2753431B21
 neighbor 10.100.100.5 password encrypted 011012261F5A1622
 neighbor 10.100.100.8 password encrypted 0508122D651D5E24
 neighbor 10.100.100.11 password encrypted 011012261F5A1622
 neighbor 10.100.100.12 password encrypted 094F5A2B5D54073F
 neighbor 10.100.100.14 password encrypted 121A1135565A1C29
 neighbor 10.100.100.23 password encrypted 12495446425A5E567C7A027D1264744155
 neighbor 10.100.100.32 password encrypted 15111F2E407B3B09
 neighbor 10.100.100.64 password encrypted 011012261F5A1622
 neighbor 10.100.100.74 password encrypted 0508122D651D5E24
 neighbor 10.100.100.128 password encrypted 011012261F5A1622
 neighbor 10.100.100.192 password encrypted 094F5A2B5D54073F
 neighbor 10.100.100.214 password encrypted 06051B03081F3934
 neighbor 10.100.101.18 password encrypted 121A0C041104
 neighbor 10.100.101.18 targeted
 interface GigabitEthernet0/10/0/1
 interface GigabitEthernet0/11/0/0
 interface TenGigE0/0/0/0
 interface TenGigE0/1/0/0
 interface TenGigE0/2/0/0
 interface TenGigE0/3/0/0
 interface TenGigE0/4/0/0
 interface TenGigE0/5/0/0
 interface TenGigE0/6/0/0
 interface TenGigE0/12/0/0
 interface TenGigE0/13/0/0
 interface POS0/9/3/0
Akash Agrawal
LDP is not coming up due to password mismatch. On PE1 you have configured ctB$1pM while on core it is ctB$1PM. Please correct password on either side and check if LDP comes up.
From below logs it is clear that both routers are able to transmit/receive each other's LDP hello. It should be related to password only.
PE1#sh mpls ldp disc
 Local LDP Identifier:
    10.100.100.214:0
    Discovery Sources:
    Interfaces:
        GigabitEthernet1/0/0 (ldp): xmit/recv
            LDP Id: 10.100.100.1:0
P1#sh mpls ldp discov
Local LDP Identifier: 10.100.100.1:0
Discovery Sources:
  Interfaces:
    GigabitEthernet0/10/0/2 : xmit/recv
      LDP Id: 10.100.100.214:0, Transport address: 10.100.100.214
          Hold time: 15 sec (local:15 sec, peer:15 sec)
Vinit Jain
First of all I want to point out that you are using pretty old code on both the PE and the P router. its necessary to upgrade the software on both these routers.
Coming to the problem, so you are seeing LDP neighborship from one side but not from other. Is that correct. Could you please confirm if you have loopback to loopback reachability between PE and P router.
Could you please share the below output:
- show mpls ldp bindings <P_loopback> (on PE1)
- show tcp brief | in .646
- show mls cef exception status
- were there any recent changes done on the router after which this problem was triggered.
Also, please capture the show log output (in a file) from the PE router to see if there are any error logs reported. if there is any problem on the 7600 platform, you might be get some errors there.
Vinit
--Vinit
Hi Vint,
Thanks for reply.. I agree, code on these boxes are too old, but the boxes will swap out soon.
Actually, I am not seeing LDP from both ways:
P to PE via loopback
P1#sh ip route 10.100.100.214
Routing entry for 10.100.100.214/32
  Known via "ospf 100", distance 110, metric 11, type intra area
  Installed Oct 13 14:38:27.650
    10.100.104.182, from 10.100.100.214, via GigabitEthernet0/10/0/2
      Route metric is 11
  No advertising protos.
P1#sh run int loo0
interface Loopback0
 ipv4 address 10.100.100.1 255.255.255.255
P1#ping 10.100.100.214 source loopback0
Sending 5, 100-byte ICMP Echos to 10.100.100.214, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 6/6/7 ms
P1#sh tcp brief | in .646
0x482784a8      0      0  10.100.100.1:646       10.100.100.23:44187    ESTAB
0x4829c450      0      0  10.100.100.1:646       10.100.100.2:43822     ESTAB
0x48299670      0      0  10.100.100.1:646       10.100.100.64:17206    ESTAB
0x48297654      0      0  10.100.100.1:646       10.100.100.128:21443   ESTAB
0x482992fc      0      0  10.100.100.1:646       10.100.100.11:41045    ESTAB
0x4829a004      0      0  10.100.100.1:646       10.100.100.12:50278    ESTAB
0x4829751c      0      0  10.100.100.1:646       10.100.100.32:30817    ESTAB
0x48296134      0      0  0.0.0.0:646            0.0.0.0:0              LISTEN
P1#sh cef exceptions
CEF Exception Statistics
Node: 0/0/CPU0
  Slow encap  packets :               0
  Unsupported packets :               0
  Redirect    packets :               0
  Receive     packets :          110696
  Broadcast   packets :               0
  IP options  packets :               1
  TTL expired packets :         5155941
  Fragmented  packets :               0
Node: 0/1/CPU0
  Receive     packets :               0
  IP options  packets :               0
  TTL expired packets :               0
Node: 0/2/CPU0
  Receive     packets :               0
Node: 0/3/CPU0
  Receive     packets :               0
Node: 0/4/CPU0
  Receive     packets :               1
  TTL expired packets :         4835749
Node: 0/5/CPU0
  Receive     packets :               1
  TTL expired packets :         4834837
Node: 0/6/CPU0
  Receive     packets :               0
Node: 0/8/CPU0
  Slow encap  packets :              16
  Receive     packets :              90
Node: 0/9/CPU0
  Receive     packets :         7166323
  TTL expired packets :         6844725
Node: 0/10/CPU0
  Slow encap  packets :               2
  Receive     packets :            2869
  TTL expired packets :         5037355
Node: 0/12/CPU0
  Receive     packets :             167
  TTL expired packets :         4956397
Node: 0/13/CPU0
  Receive     packets :               5
  TTL expired packets :         4931750
Discovery Sources:
  Interfaces:
    GigabitEthernet0/10/0/1 : xmit/recv
      LDP Id: 10.100.100.128:0, Transport address: 10.100.100.128
    POS0/9/3/0 : xmit/recv
      LDP Id: 10.100.100.32:0, Transport address: 10.100.100.32
    TenGigE0/0/0/0 : xmit/recv
      LDP Id: 10.100.100.2:0, Transport address: 10.100.100.2
    TenGigE0/12/0/0 : xmit/recv
      LDP Id: 10.100.100.23:0, Transport address: 10.100.100.23
    TenGigE0/13/0/0 : xmit/recv
      LDP Id: 10.100.100.64:0, Transport address: 10.100.100.64
    TenGigE0/4/0/0 : xmit/recv
      LDP Id: 10.100.100.11:0, Transport address: 10.100.101.18
    TenGigE0/5/0/0 : xmit/recv
      LDP Id: 10.100.100.12:0, Transport address: 10.100.100.12
  Targeted Hellos:
    10.100.100.1 -> 10.100.101.18 (active), xmit/recv
          Hold time: 90 sec (local:90 sec, peer:90 sec)
    10.100.100.1 -> 10.100.100.23 (passive), xmit/recv
Broken PE to P
PE1#ping 10.100.100.1 sour loop0
Sending 5, 100-byte ICMP Echos to 10.100.100.1, timeout is 2 seconds:
Packet sent with a source address of 10.100.100.214
Success rate is 100 percent (5/5), round-trip min/avg/max = 8/9/12 ms
PE1#sh ip route 10.100.100.1
Routing entry for 10.100.100.1/32
  Last update from 10.100.104.181 on GigabitEthernet1/0/0, 15:47:00 ago
  * 10.100.104.181, from 10.100.100.1, 15:47:00 ago, via GigabitEthernet1/0/0
      Route metric is 11, traffic share count is 1
PE1#sh mpls ldp bind 10.100.100.1 255.255.255.255
  lib entry: 10.100.100.1/32, rev 749
        local binding:  label: 262
        remote binding: lsr: 10.100.100.83:0, label: 562
        remote binding: lsr: 10.100.100.3:0, label: 381
        remote binding: lsr: 10.100.100.2:0, label: 3703
        remote binding: lsr: 10.100.100.12:0, label: 121
        remote binding: lsr: 10.100.100.73:0, label: 226
        remote binding: lsr: 10.100.100.75:0, label: 525
        remote binding: lsr: 10.100.100.14:0, label: 203
        remote binding: lsr: 10.100.100.129:0, label: 47
        remote binding: lsr: 10.100.100.193:0, label: 243
        remote binding: lsr: 10.100.100.132:0, label: 245
        remote binding: lsr: 10.100.100.65:0, label: 1822
        remote binding: lsr: 10.100.100.5:0, label: 194
        remote binding: lsr: 10.100.100.11:0, label: 104
        remote binding: lsr: 10.100.100.203:0, label: 209
        remote binding: lsr: 10.100.100.138:0, label: 69
        remote binding: lsr: 10.100.100.218:0, label: 53
        remote binding: lsr: 10.100.100.136:0, label: 137
        remote binding: lsr: 10.100.100.220:0, label: 292
PE1#sh tcp brief | in .646
4AB5D810  10.100.100.214.19522        10.100.100.1.646            SYNSENT
4AB3B7B0  10.100.100.214.48675        10.100.100.193.646          ESTAB
549735E4  10.100.100.214.646          10.100.100.218.15433        ESTAB
4AB46FC8  10.100.100.214.50658        10.100.100.11.646           ESTAB
4AB37B68  10.100.100.214.41165        10.100.100.14.646           ESTAB
4AD8D48C  10.100.100.214.21004        10.100.100.12.646           ESTAB
4ABB5E2C  10.100.100.214.22033        10.100.100.3.646            ESTAB
4ABB5838  10.100.100.214.44131        10.100.100.83.646           ESTAB
4AB469D4  10.100.100.214.37750        10.100.100.5.646            ESTAB
4AB4AFEC  10.100.100.214.19797        10.100.100.203.646          ESTAB
4AB3B030  10.100.100.214.32532        10.100.100.129.646          ESTAB
4AB40AD4  10.100.100.214.47057        10.100.100.132.646          ESTAB
4AB33C20  10.100.100.214.20654        10.100.100.75.646           ESTAB
54972FF0  10.100.100.214.60280        10.100.100.138.646          ESTAB
4AB2ED4C  10.100.100.214.35704        10.100.100.73.646           ESTAB
4AB5CBC0  10.100.100.214.56782        10.100.100.136.646          ESTAB
4AD8C604  10.100.100.214.34284        10.100.100.2.646            ESTAB
4AB41C80  10.100.100.214.25738        10.100.100.65.646           ESTAB
5496F6D0  10.100.100.214.646          10.100.100.220.25814        ESTAB
PE1#sh mls cef exception status
Current IPv4 FIB exception state = FALSE
Current IPv6 FIB exception state = FALSE
Current MPLS FIB exception state = FALSE
    10.100.100.214:0
    Discovery Sources:
    Interfaces:
    Targeted Hellos:
        10.100.100.214 -> 10.100.100.2 (ldp): active/passive, xmit/recv
        10.100.100.214 -> 10.100.100.3 (ldp): active/passive, xmit/recv
            LDP Id: 10.100.100.3:0
        10.100.100.214 -> 10.100.100.5 (ldp): active/passive, xmit/recv
            LDP Id: 10.100.100.5:0
        10.100.100.214 -> 10.100.100.8 (ldp): active, xmit
        10.100.100.214 -> 10.100.100.11 (ldp): active/passive, xmit/recv
        10.100.100.214 -> 10.100.100.12 (ldp): active/passive, xmit/recv
        10.100.100.214 -> 10.100.100.14 (ldp): active/passive, xmit/recv
            LDP Id: 10.100.100.14:0
        10.100.100.214 -> 10.100.100.65 (ldp): active/passive, xmit/recv
            LDP Id: 10.100.100.65:0
        10.100.100.214 -> 10.100.100.73 (ldp): active/passive, xmit/recv
            LDP Id: 10.100.100.73:0
        10.100.100.214 -> 10.100.100.75 (ldp): active/passive, xmit/recv
            LDP Id: 10.100.100.75:0
        10.100.100.214 -> 10.100.100.83 (ldp): active/passive, xmit/recv
            LDP Id: 10.100.100.83:0
        10.100.100.214 -> 10.100.100.129 (ldp): active/passive, xmit/recv
            LDP Id: 10.100.100.129:0
        10.100.100.214 -> 10.100.100.132 (ldp): active/passive, xmit/recv
            LDP Id: 10.100.100.132:0
        10.100.100.214 -> 10.100.100.134 (ldp): active, xmit
        10.100.100.214 -> 10.100.100.136 (ldp): active/passive, xmit/recv
            LDP Id: 10.100.100.136:0
        10.100.100.214 -> 10.100.100.138 (ldp): active/passive, xmit/recv
            LDP Id: 10.100.100.138:0
        10.100.100.214 -> 10.100.100.193 (ldp): active/passive, xmit/recv
            LDP Id: 10.100.100.193:0
        10.100.100.214 -> 10.100.100.203 (ldp): active/passive, xmit/recv
            LDP Id: 10.100.100.203:0
        10.100.100.214 -> 10.100.100.218 (ldp): active/passive, xmit/recv
            LDP Id: 10.100.100.218:0
        10.100.100.214 -> 10.100.100.220 (ldp): active/passive, xmit/recv
            LDP Id: 10.100.100.220:0
Working PE to P example
PE2#ping 10.100.100.1 source loop0
Success rate is 100 percent (5/5), round-trip min/avg/max = 4/4/4 ms
PE2#sh ip route 10.100.100.1
  Known via "ospf 100", distance 110, metric 2, type intra area
  Last update from 10.100.101.1 on TenGigabitEthernet1/0/0, 7w0d ago
  * 10.100.101.1, from 10.100.100.1, 7w0d ago, via TenGigabitEthernet1/0/0
      Route metric is 2, traffic share count is 1
PE2#sh mpls ldp bind 10.100.100.1 255.255.255.255
  lib entry: 10.100.100.1/32, rev 4052
        local binding:  label: 3703
        remote binding: lsr: 10.100.100.33:0, label: 26
        remote binding: lsr: 10.100.100.20:0, label: 233
        remote binding: lsr: 10.100.100.81:0, label: 283
        remote binding: lsr: 10.100.100.24:0, label: 8373
        remote binding: lsr: 10.100.100.25:0, label: 4169
        remote binding: lsr: 10.100.100.79:0, label: 591
        remote binding: lsr: 10.100.100.1:0, label: imp-null
        remote binding: lsr: 10.100.100.8:0, label: 72
        remote binding: lsr: 10.100.100.207:0, label: 276
        remote binding: lsr: 10.100.100.80:0, label: 392
        remote binding: lsr: 10.100.100.19:0, label: 56
        remote binding: lsr: 10.100.100.208:0, label: 375
        remote binding: lsr: 10.100.100.209:0, label: 258
        remote binding: lsr: 10.100.100.77:0, label: 1077
        remote binding: lsr: 10.100.100.214:0, label: 262
PE2#sh tcp brief | in .646
570BFF30  10.100.100.2.646            10.100.100.20.51011         ESTAB
571A72A8  10.100.100.2.646            10.100.100.11.32692         ESTAB
4A63C448  10.100.100.2.646            10.100.100.12.31796         ESTAB
4A63DEE0  10.100.100.2.646            10.100.100.129.62011        ESTAB
4A3CBB44  10.100.100.2.646            10.100.100.214.34284        ESTAB
56B205A8  10.100.100.2.646            10.100.100.79.48998         ESTAB
49AEEF18  10.100.100.2.646            10.100.100.25.40732         ESTAB
56E319D0  10.100.100.2.646            10.100.100.81.48384         ESTAB
56ED0B8C  10.100.100.2.646            10.100.100.220.17975        ESTAB
56B1234C  10.100.100.2.646            10.100.100.65.33556         ESTAB
5720FE8C  10.100.100.2.646            10.100.100.8.24703          ESTAB
46788578  10.100.100.2.646            10.100.100.14.58600         ESTAB
49C0E21C  10.100.100.2.43822          10.100.100.1.646            ESTAB
5658D384  10.100.100.2.646            10.100.100.138.65214        ESTAB
4AA33938  10.100.100.2.646            10.100.100.80.29038         ESTAB
56B47D68  10.100.100.2.646            10.100.100.75.26130         ESTAB
4A8A0DC4  10.100.100.2.646            10.100.100.136.48260        ESTAB
4A8466BC  10.100.100.2.646            10.100.100.33.58395         ESTAB
4A91565C  10.100.100.2.646            10.100.100.208.56612        ESTAB
4A5488C0  10.100.100.2.646            10.100.100.132.12259        ESTAB
4AA9A9C4  10.100.100.2.646            10.100.100.209.16326        ESTAB
4A8E3738  10.100.100.2.646            10.100.100.3.42991          ESTAB
4AA15A2C  10.100.100.2.60646          10.100.111.224.49           TIMEWAIT
571CAE70  10.100.100.2.646            10.100.100.19.57659         ESTAB
4A6DDA48  10.100.100.2.646            10.100.100.83.14511         ESTAB
4A73AE68  10.100.100.2.646            10.100.100.207.38249        ESTAB
4A43536C  10.100.100.2.646            10.100.100.193.21168        ESTAB
4A883850  10.100.100.2.646            10.100.100.24.27521         ESTAB
56F58F28  10.100.100.2.646            10.100.100.5.53889          ESTAB
573015E0  10.100.100.2.646            10.100.100.73.57339         ESTAB
4AB15038  10.100.100.2.646            10.100.100.77.12405         ESTAB
4A3F4908  10.100.100.2.646            10.100.100.218.26383        ESTAB
56E77794  10.100.100.2.646            10.100.100.203.61840        ESTAB
PE1#sh mls cef exception ?
  priorities  recovery priorities
  status      ERM status
NAS_CEN_PE2#sh mls cef exception status
Akash Agrawal
    10.100.100.214:0
    Discovery Sources:
    Interfaces:
Discovery Sources:
  Interfaces:
Hi Akash,
Thank you so much!!
Nail on the head, 100% success immediately.
PE1(config)#mpls ldp neighbor 10.100.100.1 password ctB$1PM
PE1#sh mpls ldp neigh 10.100.100.1
    Peer LDP Ident: 10.100.100.1:0; Local LDP Ident 10.100.100.214:0
        TCP connection: 10.100.100.1.646 - 10.100.100.214.23460
        State: Oper; Msgs sent/rcvd: 173/173; Downstream
        Up time: 00:00:12
          GigabitEthernet1/0/0, Src IP addr: 10.100.104.181
          10.100.100.1    10.100.101.90   10.100.101.37   10.100.101.17
          10.100.101.1    10.100.101.45   10.100.101.41   10.100.101.21
          10.100.104.181  10.100.105.2
PE1#ping vrf SONUS 10.120.4.1 repeat 2
Success rate is 100 percent (2/2), round-trip min/avg/max = 8/8/8 ms
PE1#sh mpls forw 10.120.4.1
Local  Outgoing      Prefix            Bytes Label   Outgoing   Next Hop
Label  Label or VC   or Tunnel Id      Switched      interface
PE1#sh ip cef vrf SONUS 10.120.4.1
10.120.4.0/27
  nexthop 10.100.104.181 GigabitEthernet1/0/0 label 16000 1809
PE1#trace mpls ipv4 10.100.100.1 255.255.255.255
Tracing MPLS Label Switched Path to 10.100.100.1/32, timeout is 2 seconds
  0 10.100.104.182 MRU 9180 [Labels: implicit-null Exp: 0]
Good talent and thanks again man... I owe you a few beers anytime :-)
