MPLS TE , path-option not switching automatically
hamalawy1
hi everyone,
i'm doing this lab with 1 tunnel with 2 path-options specified explicitly... the problem is when the first path is down, the second comes up.. but when the first comes up again.. the second path remains active.. how can i fix this?.. here's some data for you
R1
mpls traffic-eng tunnels
mpls traffic-eng link-management timers periodic-flooding 30
interface Loopback0
ip address 1.1.1.1 255.255.255.255
ip ospf 1 area 0
interface Tunnel0
ip unnumbered Loopback0
tunnel destination 7.7.7.7
tunnel mode mpls traffic-eng
tunnel mpls traffic-eng autoroute announce
tunnel mpls traffic-eng priority 7 7
tunnel mpls traffic-eng bandwidth  2000
tunnel mpls traffic-eng path-option 1 explicit name R1-R2-R3-R4-R5-R6-R7
tunnel mpls traffic-eng path-option 2 explicit name R1-R2-R3-R4-R6-R7
tunnel mpls traffic-eng record-route
no routing dynamic
interface FastEthernet0/0
ip address 10.1.2.1 255.255.255.252
ip ospf 1 area 0
speed 100
full-duplex
mpls ip
ip rsvp bandwidth 5000
interface FastEthernet0/1
no ip address
shutdown
speed 100
full-duplex
router ospf 1
mpls traffic-eng router-id Loopback0
mpls traffic-eng area 0
log-adjacency-changes
ip forward-protocol nd
ip http server
no ip http secure-server
ip explicit-path name R1-R2-R3-R4-R5-R6-R7 enable
next-address 10.1.2.2
next-address 10.2.3.2
next-address 10.3.4.2
next-address 10.4.5.2
next-address 10.5.6.2
next-address 10.6.7.2
next-address 7.7.7.7
ip explicit-path name R1-R2-R3-R4-R6-R7 enable
next-address 10.4.6.2
mpls ldp router-id Loopback0 force
R1#sh mpls traffic-eng tunnels
Name: R1_t0                               (Tunnel0) Destination: 7.7.7.7
  Status:
    Admin: up         Oper: up     Path: valid       Signalling: connected
    path option 1, type explicit R1-R2-R3-R4-R5-R6-R7 (Basis for Setup, path weight 6)
    path option 2, type explicit R1-R2-R3-R4-R6-R7
  Config Parameters:
    Bandwidth: 2000     kbps (Global)  Priority: 7  7   Affinity: 0x0/0xFFFF
    Metric Type: TE (default)
    AutoRoute:  enabled   LockDown: disabled  Loadshare: 2000     bw-based
    auto-bw: disabled
  InLabel  :  -
  OutLabel : FastEthernet0/0, 28
  RSVP Signalling Info:
       Src 1.1.1.1, Dst 7.7.7.7, Tun_Id 0, Tun_Instance 27
    RSVP Path Info:
      My Address: 10.1.2.1
      Explicit Route: 10.1.2.2 10.2.3.1 10.2.3.2 10.3.4.1
                      10.3.4.2 10.4.5.1 10.4.5.2 10.5.6.1
                      10.5.6.2 10.6.7.1 10.6.7.2 7.7.7.7
      Record Route:
      Tspec: ave rate=2000 kbits, burst=1000 bytes, peak rate=2000 kbits
    RSVP Resv Info:
      Record Route: 10.1.2.2 10.2.3.2 10.3.4.2 10.4.5.2
                    10.5.6.2 10.6.7.2
      Fspec: ave rate=2000 kbits, burst=1000 bytes, peak rate=2000 kbits
  History:
    Tunnel:
      Time since created: 19 minutes, 22 seconds
      Time since path change: 36 seconds
    Current LSP:
      Uptime: 36 seconds
      Selection: reoptimation
    Prior LSP:
      ID: path option 2 [26]
      Removal Trigger: path error
LSP Tunnel R7_t0 is signalled, connection is up
  InLabel  : FastEthernet0/0, implicit-null
  OutLabel :  -
       Src 7.7.7.7, Dst 1.1.1.1, Tun_Id 0, Tun_Instance 41
    RSVP Path Info:
      My Address: 1.1.1.1
      Explicit Route:  NONE
                    10.5.6.2 10.6.7.2
    RSVP Resv Info:
      Record Route:
THEN WHEN THE LINK FROM R4 TO R6 DIES
  Status:
    path option 2, type explicit R1-R2-R3-R4-R6-R7 (Basis for Setup, path weight 5)
  Config Parameters:
    auto-bw: disabled
  InLabel  :  -
       Src 1.1.1.1, Dst 7.7.7.7, Tun_Id 0, Tun_Instance 29
    RSVP Path Info:
                      10.3.4.2 10.4.6.1 10.4.6.2 10.6.7.1
                      10.6.7.2 7.7.7.7
      Record Route:
    RSVP Resv Info:
      Record Route: 10.1.2.2 10.2.3.2 10.3.4.2 10.4.6.2
                    10.6.7.2
  History:
    Tunnel:
      Time since created: 19 minutes, 56 seconds
      Time since path change: 3 seconds
    Current LSP:
      Uptime: 3 seconds
    Prior LSP:
      ID: path option 1 [27]
      Last Error: PCALC:: Can't use link 10.4.5.1 on node 4.4.4.4
WHEN THE LINK BETWEEN R4 TO R6 IS UP AGAIN.. REMAINS THE SAME
any ideas.. sorry but my battery died when i was posting this... hope this gives you a complete overview..
6 Replies 6
Atif Awan
hamalawy1 wrote:
hi everyone,
i'm doing this lab where i has 1 tunnel with 2 path-options specified explicitly... the problem is when the first path is down, the second comes up.. but when the first comes up again.. the second path remains active.. how can i fix this?.. here's some data for you
R1
Is your first path 'better' than the second path (think from a CSPF perspective). If yes then with default settings you will need to wait for the periodic reoptimization timer to kickin before the tunnel reoptimizes to the best path. Default setting is 3600 seconds if I recall correctly.
Atif
yes, i tried changing the timer to 30 sec but no use.. but you are correct from the CSPF prespective, it's indeed not better than the other pass, but the point is this is labeled as OPTION 1 and the other is OPTION 2 ... isn't option 1 supposed to have some priority over the latter one? i posted the configuration and some show commands.. maybe you can help
thank you again atif
Reoptimzation will happen in case a better path is found. If there is no better path then the current path will continue to be used.
When a tunnel is being initially setup the path options are tried sequentially so in this case your Option-1 will be tried first and if it is valid it will be used. However, once a tunnel is setup via Option-2 (Option-1 was invalid) it will move back to Option-1 in case it is a better path. If it is not then the tunnel will not reoptimize.
Atif
Hi Atif,
     Sorry my late to reply, possibly many things have changed. In any case, I have a tunnel between an ASR900 and ASR9000 and if the primary path goes down it will be picked again when restored even if not optimal.  I saw that in every re-optimization the system tries always the path options sequentially.
interface Tunnel1001
description --- Tunnel1001: test ---
ip unnumbered Loopback1
load-interval 30
mpls ip
tunnel destination 192.168.118.129
tunnel mpls traffic-eng path-option 10 explicit name tunnel1001.p0 <--- worst one
tunnel mpls traffic-eng path-option 20 dynamic <--- better one
If the explicit-path tunnel1001.p0 fail the system goes to the dynamic option. When I fix the explicit path this happen:
Jun 22 19:49:00.411:     192.168.118.129: 192.168.118.129
Jun 22 19:49:00.411: TE-PCALC-API: 192.168.201.1_1281->192.168.118.129_1001 {7}: P2P LSP Path Lookup result: success
Jun 22 19:49:00.411: TE-REOPT-HE: Tunnel1001 [1281]->192.168.118.129 new path: option 10 [1281], weight 125
Jun 22 19:49:00.411: TE-REOPT-HE: Tunnel1001 [1281]->192.168.118.129 old path: option 20 [1214], weight 3
Jun 22 19:49:00.411: TE-REOPT-HE: Tunnel1001 [1281]: set as reopt
Jun 22 19:49:00.515: TE-REOPT-HE: Tunnel1001 [1281] delay install 3 sec
As you can see the new path has weight 125 but it becomes the active one.
Thankyou, Gianrico Fichera
hbruyere
Did you give a try with this?
int tunnel0
 tunnel mpls traffic-eng path-option protect 1 explicit name
http://www.cisco.com/en/US/docs/ios/mpls/configuration/guide/mp_te_path_prot.html
Herve
Ps: did not notice I was resurrecting a old tread
In addition to what atif said...
Path protection option we are using for keeping resource ready incase primary fails. it is quite same as using different path-option ..and the only difference is path protection has better convergence than igp convergence because it is presignalled LSP path.
Normally we configure path-option for explicit path and leave last statement as a dynamic path as a backup of all path-option.
We have preempt facility but it is between tunnels and not between different path-option.
We configure path-option for explicit path because it is explicit and it could be possible that the next-address specified in explicit path is not reachable or you want to do some activity on mentioned path so as a backup it will be rerouted to next path-option.
If you want your traffic always prefer first path option as and when available you need to create
two tunnels and you can put some priority so at time of reoptimization it will preempt to first one only
Hope this is useful
