08-16-2005 10:53 AM
I'd appreciate it if someone can tell me what needs to be fixed below for me to export subnets from VRF customer1 to VRF mpls-monitor. Right now I see private /30 routes on the route table of customer1 VRF but nothing is exported to the route table of the mpls-monitor VRF.
ip vrf customer1
rd 1:119
export map from-rd119
route-target export 1:119
route-target import 1:119
ip vrf mpls-monitor
rd 1:100
route-target export 1:100
route-target import 1:100
route-map from-rd119 permit 10
match ip address prefix-list rfc-1918
set extcommunity rt 1:100 additive
route-map from-rd119 permit 20
match ip address default
ip prefix-list rfc-1918 seq 10 permit 10.0.0.0/8 ge 30 le 31
ip access-list standard default
permit any
Below lists the current bgp table of cutomer1:
PE1#show ip bgp v vrf customer1
BGP table version is 184, local router ID is 10.0.1.19
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
r RIB-failure, S Stale
Origin codes: i - IGP, e - EGP, ? - incomplete
Network Next Hop Metric LocPrf Weight Path
Route Distinguisher: 1:119 (default for vrf customer1)
*>i0.0.0.0 10.1.1.11 0 100 0 ?
* i 10.1.1.11 0 100 0 ?
*>i10.10.119.0/30 10.1.1.11 0 100 0 i
* i 10.1.1.11 0 100 0 i
*>i10.10.119.4/30 10.0.1.13 0 100 0 i
* i 10.0.1.13 0 100 0 i
*>i10.10.119.8/30 10.2.1.11 0 100 0 i
* i 10.2.1.11 0 100 0 i
*>i192.168.0.0 10.1.1.11 0 100 0 ?
* i192.168.1.0 10.0.1.13 0 100 0 ?
*>i 10.0.1.13 0 100 0 ?
* i192.168.2.0 10.2.1.11 0 100 0 ?
*>i 10.2.1.11 0 100 0 ?
08-16-2005 12:15 PM
This should work just fine. Can you include your BGP configuration.
08-16-2005 12:42 PM
Hi Harold, thanks for the quick response.
Here is my BGP config. I am also running 12.4.(3) if the IOS makes any difference.
router bgp 1
no synchronization
no bgp log-neighbor-changes
neighbor rrserver peer-group
neighbor rrserver remote-as 1
neighbor rrserver update-source Loopback1
neighbor rrserver next-hop-self
neighbor 10.0.1.1 peer-group rrserver
neighbor 10.0.1.2 peer-group rrserver
maximum-paths 4
no auto-summary
address-family vpnv4
neighbor rrserver send-community extended
neighbor 10.0.1.1 activate
neighbor 10.0.1.2 activate
exit-address-family
address-family nsap
maximum-paths 4
no synchronization
exit-address-family
address-family ipv4 vrf mpls-monitor
redistribute static
no auto-summary
no synchronization
exit-address-family
address-family ipv4 vrf customer1
no auto-summary
no synchronization
exit-address-family
08-22-2005 04:37 AM
when you do a show route-map or something like show ip prefix-list (trying to do the same as show access-list) do you see any matches being done?
09-01-2005 11:35 AM
I believe you are missing just one line. Try the following addition:
ip vrf customer1
rd 1:119
route-target export 1:100 ; Try this addition...
09-01-2005 01:27 PM
Hi Justin,
I tried that and had no luck either. From what I understand, the export-map should be able to take of this for me without adding another route-target statement.
There is one thing I notice though. The only routes that I can export are the ones that are connected or static. I have not done a lot of route imports and exports but if this is how it really behaves then I'll just have to configure every PE router for exports.
10-18-2005 11:33 AM
Hi ..
The problems that you are running into, looks like the same ones I had,
Here is a snap, of my working configuration,
ip vrf Customer1
rd 1:10030
export map Customer1
route-target export 1:10030
route-target import 1:10030
route-target import 1:10053
route-map Customer1 permit 10
match ip address 16
set extcommunity rt 1:1 additive
access-list 16 permit 10.9.133.128 0.0.0.127
access-list 16 permit 10.9.133.32 0.0.0.3
ip vrf Management
rd 1:10053
route-target export 1:10053
I also had a problem, that routes was learned from iBGP, and was not propagated to eBGP peers.
The reason i set extcommunity to 1:1 additive, and only import 1:1 i my management, is if you export to 1:10053, and you try to import 1:10053 in another VRF, you se all exported networks, i any other vrf where you import you management vrf
Let me know if this works..
-./Peter
10-18-2005 01:09 PM
From my understanding (someone can clarify this) your route-target community additions work the route are being imported into the BGP VPNV4. Hence, for routes leanrt via iBGP across the VPNV4, the route-target export or the export map command has no effect.
For routes learnt from the PE to CE IGP, or from the static or coonected routes on the PE, the desired route-targets will be applied.
I've never tried this before, but it could work. Create a route-map to match the prefix you want and add the desired community. Then apply the route-map to the VPNV4 session.
ip extcommunity-list 1 permit rt x:y
route-map comm permit 10
match extcommunity 1
set extcommunity rt x:z additive
router bgp x
neigh a.a.a.a route-map comm in
