Remote access to MPLS VPN - Using IPSEC dynamic crypto
ar
Hi.
I want to use IPSEC for remote access to MPLS VPN.
Each tunnel maps to a VRF.
I am simulating a vrf-aware IPSEC VPN Concentrator with  multiple dynamic peers on GNS.
I have two client profiles on the 7200 concentrator.
I can have both clients working.
But I noticed when doing a restart of all the session,
one of the client will stop working.
I'm getting an error of:
*Feb 18 20:58:27.811: %CRYPTO-4-IKMP_BAD_MESSAGE: IKE message from 172.16.1.2 failed its sanity check or is malformed
Which I believe means preshare keys do not match. But i am very sure they are accurate and match.
I have to re-create the whole profile so it will work again (keyring, dynamic profile, dynamic-map).
I am not sure if this is just a GNS problem or config itself.
Below is my config for the 7200 VPN concentrator.
I hope someone can share their ideas on how to this properly.
Objective: Multiple Dynamic vrf-aware IPSEC Peers
thanks
Client 1 is ABC
Clilent 2 is XYZ
ip vrf A
rd 1:1
route-target export 1:1
route-target import 1:1
ip vrf B
rd 2:2
route-target export 2:2
route-target import 2:2
crypto keyring VRF-B
  pre-shared-key  address 0.0.0.0 0.0.0.0 key XYZ
crypto keyring VRF-A
  pre-shared-key address 0.0.0.0 0.0.0.0 key ABC
crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
crypto isakmp profile XYZ
   vrf B
   keyring VRF-B
   match identity address 0.0.0.0
crypto isakmp profile ABC
   vrf A
   keyring VRF-A
crypto ipsec transform-set vpn esp-3des esp-sha-hmac
crypto dynamic-map ABC 10
set transform-set vpn
set isakmp-profile ABC
match address ABC-remote
crypto dynamic-map XYZ 10
set isakmp-profile XYZ
match address XYZ-remote
crypto map VPN 11 ipsec-isakmp dynamic XYZ
crypto map VPN 12 ipsec-isakmp dynamic ABC
ip access-list extended  ABC-remote
permit ip 10.1.0.0 0.0.255.255 10.2.0.0 0.0.255.255
ip access-list extended XYZ-remote
ip route vrf A 10.0.0.0 255.0.0.0 172.16.1.2 global
ip route vrf B 10.2.0.0 255.255.0.0 172.16.1.3 global
interface FastEthernet1/0
description WAN-to-Internet
ip address 172.16.1.1 255.255.255.0
duplex full
speed 100
crypto map VPN
interface Loopback10
ip vrf forwarding A
ip address 10.1.1.1 255.255.255.0
interface Loopback20
ip vrf forwarding B
0 Replies 0
